Hi,
I have heard 2 different perspectives on the LLY Transfer case that comes in the 2005 HD's. COuple people say that there is no difference in the part numbers from a 2500 to a 3500 truck. Others say the 3500 is a more industrial or heavier duty unit than that in the 2500.
I have a 2005 2500HD
Here is my issue, Replaced the seal in the yoke 6 months ago due to leaking. RIght away it was leaking again, and it looks as though the transfer case needs internal work, its whining now, and does some weird noises when you engage 4 Hi to 4 LO, and utilize 4 lo.
I am just curious if as an upgrade, a 3500 is a better unit, and worth it to put in, or if there are any benefits at all?
Also, if it is a worthy upgrade, do I need to do anything to the TCCM to get it to work in the 2500?
Thanks in advance,
Thanks in advance,
