That's a ford not a chevy
Thank you captain obvious lol:roflmao:
they will not fit without lots of fender cutting my 305/55/20 on a 20x10 with -25 wouldn't clear perfect with it leveled 2.5" higher then stock
How much fabrication? Could I make it work with stock fender flares?
There is another guy on this forum with a black crew cab OBS Duramax lowered with the same wheel size and offset you are looking for... Try and find him... He has a pic from the left side of his truck and is kinda smokey looking pic... Hope this helps!
This is the setup I'm going with but I have a six inch lift that I'm lowering down... But here is a couple pics I found, I think on here, awhile back... I think it's an aggressive look that these trucks pull off if you can make it fit
Sent from my DROID RAZR HD using Tapatalk 2
http://img.photobucket.com/albums/v...B-86DD-4B6D4165BE45-8664-000003BA3B7D97B5.jpg
http://img.photobucket.com/albums/v...D-98B5-3FC819CA2965-3946-00000112D401C7E7.jpg
This is a djm 3/5 drop with overloads still in with 20x10's with a -19mm offset. I rub like a sob on the inner sides of the fenders lol. I don't care though. I think the rear needs a 1.5 or 2" spacer IMHO tires are 305/50/20 420's
Thank you! I'll sacrifice some rubbing up front for the stance I was looking for :roflmao:
