LLY: 20x10..........Will they fit?
bmr7c
30
South New Berlin NY
05 cc/sb stock height suspension. RBP only makes the 95R in 20x10. I've read countless threads and still don't have a positive answer, some say they fit, even on lowered trucks. Others say you have to trim and crank bars. I don't want to crank the bars. Looking at running 285 50 20's if I can. Want to stay around stock tire height. If I can run them - what offset? Was thinking 0 to -12. That OK or do I need to be in the positive. Thnx in advance.
TLyons90
Apr 22, 2013
1,631
Greenville, SC
Yes they will work fine! I would go with the -12 and you will prob have to trim a tad here and there but shouldnt be an issue with 285/50s!
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
-12 will stick out alittle bit more than a 0 but you'll have more assurance that a 0 offset will not rub as bad. 285/50/20 will be ok too but I personally would do a 305/50 as it looks much better. Then do a 0 offset.
2005LLY
Sep 18, 2011
379
305/50 20x10 -14 offset on my truck and my front end angles are perfectly flat and I have no rubbing
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
do 0 offset.
this is 20x10 with -12 and they rubbed with 285/50, but I was also 4" drop up front
Truck looks kinda cool... I need 285/50's so I can go a hair lower in front without rubbing to bad. That truck was my inspiration to lower my truck a few year back.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Something about a 4/6 drop on a crew cab 4wd was legit :D
bmr7c
30
South New Berlin NY
A lot of answers I like. Thanks guys. I was hoping I wasn't going to get burned at the stake for asking a question that has been asked before. And big thanks for the pics as well.
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Just food for thought. Negative offset(more rubbing) positive offset(less rub). But negative always looks better IMO
