Ive been running regular rotella 15w40 in my truck since new, but now im starting to notice my oil pressure is getting lower as the summer gets hotter. When I say low I dont mean low like what people normally complain about on duramax's (20-25 hot at idle)....I mean low like 16psi hot at idle if I get off the highway and come quickly down to a stop. My truck would only barely make the required 42psi by 1800rpm minimum spec as well.
I dont know why, maybe its because of the twins, maybe its because this engine was a GM test engine and god only knows what they were doing to it during testing etc....
When its really hot out, like 90*+, you can even BARELY hear, not really a knock, but just a unhappy 'really low oil pressure' sounding noise.
I wasnt due for an oil change, but the summer isnt getting any cooler so I had to at least try something. So I went to the auto parts store and got some 20w-50 and a new filter. Changed the oil and now I get 19psi HOT at idle after running it really hard and coming quickly down to a stop. If I let it sit and cool a bit Ill get a little more than 19psi. On the highway at 80mph I get almost 60psi and at 1800rpm I have a little under 50psi. Not as much as I would like, but its much better than before, and the engine doesnt make anymore expen$ive-sounding noises HOT at idle now.
All of these oil pressures are read from the tech 2/efilive.
Just my experience, thought I would share... :joker:
ben
ben
