Question: 2 Stroke Oil ?
LOPES
Aug 14, 2011
25
San Diego, Ca
Gona be performing an upper cylinder injector cleaning to my friends stock low mileage 03 LB7. I believe I read somewhere that 2 stroke oil can be beneficial to the fuel pressure regulator. He's had an intermittent engine light with a P0089 code and I thought if i run some 2 stroke oil through the system that it may solve his code issue. Well after I perform the cleaning cycle I was thinking about idling through another gallon of #2 with the 2 stroke oil but I'm not certain as to how much oil to add to it. I have a 16 ounce bottle of Maxima Castor 927. Its a synthetic blend made of synthetic esters and degummed castor oil. Does my plan sound okay in terms of preventative maintenance. Whats your thoughts guys. Thanks.
PhilsLB7
Way Better Than Facebook
Jun 29, 2009
810
Tennessee
Take a look at this (Rank #7 is the Wal-mart brand 2 stroke oil):
http://www.duramaxdiesels.com/forum/showpost.php?p=759621&postcount=5
Adding lubricity to the fuel, especially an LB7, will be beneficial but no one can say for sure adding some 2 stroke oil will "solve" the code issue. Don't get me wrong, some guys have added 2 stroke to the fuel tank and would help free up the FPR. It's definitely worth a shot but the FPR could be too far gone. Regarding the Maxima Castor 927, I have no experience with it. Personally I would stick with something that's on the list because it has been tested and proven.
LOPES
Aug 14, 2011
25
San Diego, Ca
Thanks Guys! Your responses are very much appreciated. I've got a ratio rite cup that will make measuring that out a breeze.
MOJO
Jul 8, 2009
166
IN
You know I have done this on all my old Cummins and when I switched over to Dirty Max and still do this. I have guys ask how & why my motor is so quite:D It works:thumb:
3,733
305
I still run it on my LB7. It helped limp a weak FPR along for an extra 40 or 50k miles, but it still eventually gave out. I started at 500:1, and worked up to 200:1 before I replaced the FPR. With the new one, I run 500:1 again.
