should i run one stage b4 the intercooler then the 2nd after or both after? any help would bee great guys thanks!!!
If your going to run a 2 stage I would run the first before and the second after the intercooler. You want a softer hit on the first stage unless you a a well sorted out chassis. Jeff
swwet man... my first stage is off boost set at 27psi when it reads that the first stage comes on then the second is off a button. so if i do one before and the second after does that sound good? and what size jetting should i run.. Thanks camomax
