Truck in signature has developed an odd vibration. Between 70-80 mph only. I have re balanced once and rotated the tires 3 times in the 4 months i have had them. (35" trail grapplers and 20" BMF novakanes)
It is lifted, but the carrier bearing has a spacer that came with the lift (RCD) brand new rancho adjustable shocks, sway bar, sway bar end links, steering stabalizer, suspension ect...
I have checked fluids, u joints, carrier bearing (the rubber is slightly worn but as a diesel tech I have seen worse and not cause this vibration)
It is not RPM related, it doesnt do it under heavy acceleration or torque. Strictly 70-80mph but the odd thing is sometimes it will rattle/vibrate so bad I will back off the throttle. Other times, it is hardly noticeable.
I am in the middle of ALOT in my life and I really dont have the time to fool with this right now so I am posting this up for suggestions, maybe something I over looked with the stress I got going on so when I do have a few minutes to work on it, I can rule out the suggestions from you guys. The truck has 77,xxx miles and i have only put 5,000 on it since I got it.
