2.6 lmm puller
HogAssWild
Nov 12, 2009
502
Ok im startin to think that i wanna get into pulling...but don't want to break the vehicle i rely on everyday... so within the next to year imma get a dually and turn.my CC/SB into a puller
I know i can't pull with twins so my plan are this...
Next 2 years (while paying my truck off) im gonna add 60% overs and dual fuelers... and later add a 2.6 turbo and move the twins i have now to my dually towtruck
Jus got a couple of questions... what power i need to be making to.be competitive? Will i need a built motor? Im thinkin of pushin 650-700 stock.motor and hope it last,
Why would be a good tire set up... wanna keep my 22s on it for the street and keep aextra set of wheels/tires for pullin... was think 33x15.50 mickey thompson Atz on some 18 beadlocks?
Should i keep the auto or switch to Zf6?
And lastly... what's a good 2.6 turbo to go with
Like i said this is a process over the next 2 years just tryin to get some ideas an start some conversation
Iceman56
Jan 19, 2009
867
Madison, SD
Strictly pulling tires, can't beat STS's IMO.
HP to be competitive is gonna depend on where you live and the pulling Org. there. I know the top 2.6 trucks in the country are 800hp. So then you will need a motor build.
For strictly pulling turbo a custom S466 would be the best.
I would also give Danville a call.
HogAssWild
Nov 12, 2009
502
how big is your wallet:joker:
I am not rich by anymeans but i think i can get it done...
"if ya can't fix it ya can't afford it" a wise man once said
Really dual fuelers injectors turbo 8 grand? Is that a good ballpark?
With that setup i could be a force to.be reckon with around here and maybe make accosional trip to scheid or ts just for fun....
Would like to be able to street it a little also, but main base is pulling tuck...possible?
Iceman56
Jan 19, 2009
867
Madison, SD
Might want to think about lockers and gears also. Lockers alone front and back are gonna be around another $1800 without install cost.:(
HogAssWild
Nov 12, 2009
502
yes i defiantly might should think about thats why i wanted to start this thread to get an idea what im in for?
axles, driveshaft, tcase brace what else am i looking at?
custom8726
2,784
Upstate N.Y
Atleast probably closer to 2k unless you find some deals.. Aprox-$1200 rear (grizzly or similar) and $800.00 front Eaton or ARB,, install is pretty easy if you are some what mechanically inclined:thumb:
custom8726
2,784
Upstate N.Y
Axles and driveshaft should be fine in that power LVL, IMO.. Dont think a T-case brace is mandatory either.. Some driveshaft loops and trans blanket might not be a bad idea though..
Iceman56
Jan 19, 2009
867
Madison, SD
Grizzly is $999 about anywhere
I would wait on the axles until they go, could wait for the driveshaft to go too, but I am pretty sure you'll break it sooner or later
MarkBroviak
DMax Junkie
2,144
509
Danville Indiana
My big 2.6 trucks are far north of 850hp and you will end up rebuilding to the entire truck in order to put the power to the ground reliably and be competitive at least in these parts of the country. Pulling is a very expensive hobby. If you haven't hooked yet and don't want to spend the big bucks, stop while you are ahead.
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
X2, its hard to get out once your in, and once your in, its never ending.;)
z79outlaw
793
Salem WI
IDK, I cancled all my plans to build a pulling truck, since I got hooked on bowhunting specifically bowhunting high country mule deer. But in hindsight I think it'd been cheaper to build a puller at the very least it'd be easier.
duramaxxin73
Mar 5, 2008
444
Indianapolis, IN
x2 it gets very addicting very fast, not trying to dissuade you from pulling, but I'm just saying if your not wanting to drop some major benjamins, and then keep putting money in it then I wouldn't do it
