18x9 -12 offset 285/60r18
jneal
Feb 12, 2008
294
Bloomington, Indiana
I've searched and can't find a definitive answer. I am looking to get new wheels and tires for my truck. I want to get eagle series 079 in super polish black that are 18x9 with -12 offset and 4.5 backspacing with nitto terra grappler 285/60r18 tires. I want to leave the truck stock ride height. The bumper valance has already been trimmed. Will they fit without rubbing? The only other option I have in that wheel is a 18x8.5 with +20 offset with 5.5 backspacing.
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
I am running 17x8 with 4.5 BS with 265/70 17's. I currently rub a little bit on the air dam and the inner fenders. So I'm thinking you may rub a bit with the 18x9 with 4.5 BS, slight trimming should take care of it. If it was me I would try and run it. The 18x8.5 with the 5.5 BS will tuck in closer to the center of the truck and should make it easier to fit that tire.
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
i run 305 65 17 with 4.5bs and -12 offset on my 02 that i just sold changing it to my 08 but rubbed a little bit i used a heat gun and remolded the inner fenders little by little until no rub or very minner rub. tb's cranked maybe 2 turns from stock. so you should be good and they look sweet.:thumb:
THEREDDEVIL
A Bad seed
Jul 28, 2010
512
Godfrey, il
That's the exact same offset, backspace and wheel and tire size I run. I'm lowered with the tbars all the way down and 3" drop shackles. I trimmed alot when I ran 35's on a leveling kit though. I have no rubbing at all. I've ran 285/75/16 and 285/70/17 without rubbing also. I would think they would fit without trimming. Iirc they r like 31.5" tall kinda like a 265/75/16.
