18" drag radial
paint94979
Beer Nazi
Sep 18, 2006
11,715
What tires are you looking to go with?
in a drag radial or slick the only tire i know is the M&H Racemaster Slick 12.00/16 its 31.5 inches tall... M&H makes a drag radial in a 17" wheel IIRC its 30" tall
paint94979
Beer Nazi
Sep 18, 2006
11,715
mickey thompson makes a 29" radial
m&h has a 29.5" radial for 17s, couple inches wider than the MT
both are close to $300 a tire
IMHO it is much better to just go with a slick which is cheaper in the long run... unless you are needing a DOT approved tire
paint94979
Beer Nazi
Sep 18, 2006
11,715
I agree 100%, but i allready have an extra pair of 18" wheels sitting in my garage.
then i'd go with the Mickey Thompson radial because its much wide than the M&H equivalent it is however much more expensive. I have a code for M&H that gets you 15% off
custom8726
2,784
Upstate N.Y
Right now I just have a set of 31" nitto A/T's on extra wheels I plan on running. If The money is there I would like to go with a Dot style drag radial in a 18" size aswell but like previously stated Its tuff to find anything over 30"s with a 18" wheel..
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
The 305/45r18 MT ET gets my vote , I ran them with good sucsess and Rob has had good luck with them also on Max'd Out , RPM @ 124mph was pretty decent and should be OK up to 132-134 mph Matt bought them from me and is still running them to this day. The taller you can gte the better but there are not alot of good choices.
