[email protected] secn shakedown run
9,905
151
Right on Adam.
Pretty soon you might be able to keep up to me on the track:D:joker:
9,905
151
No you haven't-I just didn't round up!:)
(100.82):D
What is normal psi to see drop across the IC? 3psi? Obviously 0 would be best!
559
.040 short block, studed main, crowler rods, de-lipped piston
im about same place last time.. before i lost my motor...
saveign for a turbo, studs, and dual fuelers
plus im ~200lb heavier now as well
Smokin LB7
Jul 25, 2008
191
What do you mean you lost your motor?
559
559
on 6-4-09
landed 60's
[email protected] 2.156
[email protected] 2.125
[email protected] 2.173
pulled my shift point form 3500 down to 3300 on all excep 1-2 shift... as per my dyno graph probly should pull them down to 3000 see if i can get back to 100+mph again
