11s on 35s?
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Anything is possible. 1500RWHP Dmax w/35's would run 11's
Feasible? Not really. My guess is that your shooting for 11's??? Do you have a lift with those 35's?
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
a nice 66 over an 80+ and some 60 over injectors would get you there. i run 37"s and my pig still moves like a raped ape.
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
How is the spool time with say an s366? Still learning all this but from what I've read the spool time is great on say a 4094 but you can build alot more power out of the 66?
TeaBagger2006
May 11, 2008
3,123
15
Bis ND
a 66 should light very quick. this also depends on your tuner for the most part. plushaving a pedestal lets you upgrade turbos if needed.
if you could afford a 4202r over a 5533......that would be all you will ever need:woott:
but seeing that you dont have rods makes it kind of dangerous to be in the 11's with a heavier than normal truck
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
Yea I'm in a catch 22. I bought the motor built already I wish he would have done rods too. But I know my luck and I won't be one of the lucky guys who only bend them. I would probably manage to send all 8 of mine through the block and grenade themselves somehow. Just hate to pull the motor or tear it down again just for rods and valve springs.
DieselDummy
Dirt Dummy
Oct 13, 2011
238
NY
Also if it doesn't have rods, myself would not really consider it built.
Sent from the road!!!!!
03 lb7 CC/LB
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Do you still have your stock wheels? You could always put them on for the track. That would help out quite a bit. I think 11's with a stock bottom end would be hard to do.
6,047
11s on stock bottom end and 35s?? your gunna need 700+hp to do so and have a good track setup. i dont see it happening reliably. I ran a 13.0 with twins and stock sticks/cp3 on 37s and a soft launch. i soon after bent my rods but ran it hard for two months prior. Once my motor is done, im lookin at running somewhere in the twelves (hopeing for mid 12s) and will be around 650hp on stock sticks, same twins and dual cp3s. i may do 45% overs but its up in the air right now
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
Thanks guys. It looks like I may be re evaluating the route I'm going to take. Looking like I'll need rods and valve springs before I start making serious power on the big tires. Is there anything else I need to replace to make mid 700hp reliably?
6,047
basically what you have, bigger injectors to drop your pw, a good sized single or twins, and a modded single pump or dual cp3s and you should be good for that if not more
