Well Im looking for an 11.9 ET. Im sure Ill need to build for more and dial down. Recommend me a fuel and air setup! Truck weighs as it sits about 6500lbs. Should be about 6k, or less hopefully, when Im done with it.
S475 over stock lmm on proxies and bmfs got me 12.1.
Had 60k hard miles on the tune, so I figure it had more left in it since the motor never went.
6300lbs also.
What did you run for fuel?
Depending on your weight you will need about 650hp at the tires to run 11.9x consistantly.
I went 11.82@114 with 40 overs, cp3k from fleece, box s475/stock, stock motor LLY at 6000DA. CCSB 6750lbs right at 675rwhp or so.
LLYs are faster by nature than an old ass lb7.
Lol idk I've seen some old ass LB7s click off some fast passes around here...unless your just a LB7 hater Steve :hug:
I am just into the more modern technology of my 12 year old truck lol
I would need to be in the 5500lb range to hit 11s with only 650. Not sure if I can loose that much weight in an ecsb.
My lbz went 11.9 @ 6800 pounds with 45s dual pumps and a 366 and went 11.6 @ 117 on nitrous until it decided to snap motor mounts and bend valves
How consistent was it at hitting 11.9?
I have a bd staging limiter that doesn't do the trick on a zf buy would be nice for consistent launches on an auto. There's probably a ton of ways to hit a 11.9, are you gonna be bracket racing?
