This setup just went 1130 no correction. Same setup on a LMM a year ago went 1053 on two stock pumps. This setup has scene 100 psi n both were street trucks. The LML we believe could go 1200+ with two stock cp3 rather then cp4 n put a set of pistons in it.
https://www.facebook.com/empireperfeng
With more left on the table and making 85+ Psi of boost this street truck is ready to return to its owner. It was decided in our best interest to put a cap on it. We firmly believe this truck and setup could touch 1200hp.
-Built Motor by Empire Performance Engineering
- RR Connecting Rods
- Stock Cut and De Lipped Pistons (road block to pushing truck farther)
- Stage 2 Valve Train and Push Rods by Empire Performance Engineering
- Stock Un Ported Heads
- Cam Shaft Stage 2 Empire Performance Engineering
Turbo Kit
- Turbo from Precision Turbo & Engine PT88 atmosphere HP71 High Pressure using one Precision 46mm Wastegate.
- Turbo Kit done by Empire Performance Engineering
Fuel System
- Stock CP4 with H&S Motorsports dual pump kit Using Stock Displacement CP3
- 100% over Bosch Motorsports Nozzles
- Air Dog 165 gph Lift pump.
Transmission
- Fully Built SunCoast Performance Transmission.
Tuning Provided by
- MOTOR OPS using EFI Live Software.
