Hi everyone,
My aim is 1000rwhp on diesel.
I have the following parts
Socal Diesel 7.1 engine
Mahle Forged Piston, Carrilos rods, Drag racing cam for ported heads, 14mm head studs, main studs, billet main caps, Stage 2 cnc ported heads, valve springs, etc
15.5 compression
Internally balanced
How much fuel do I need?
I have available 100% injectors or 200% injectors? Is this going to be enough?
I have the 12mm exergy CP3, is this going to be enough on a single pump?? Do I need dual pumps? Whats the max a single had made before?
It has a Airdog II 250gph lift pump, -10 fuel lines to cp3 pump. Fuel cooler in the return circuit.
AIR/Boost, whats it going to take?
What turbo or turbo combo have in the pasts supply enough air?
I have a GTX4202r, I also have a GT45 and a GT47 available.
I would like to keep this a single turbo if possible, but if I need to build a compound setup I will. I have HSP Diesel 2 1/4 billet manifolds and up-pipes. 3" high flow intake bridge.
So what has worked in the past for you?
Thanks in advanced.
Heath
15.5 compression
Internally balanced
Thanks in advanced.
Heath
