LB7: -10 an oil cooling setup
diesel53
Sep 16, 2010
907
AZ
Is a -10 an setup sufficent for the oil flow rate or is -12an what is needed from the adapter through the cooler? I've looked and may have missed it in one of the oil cooling threads.
03spoolindmax
Nov 9, 2011
674
Mi
I'm running 12 an lines and fittings on my oil cooler. Although where the fittings go into the cooler and filter adapter they go from 12an to 1/2" npt
diesel53
Sep 16, 2010
907
AZ
Thanks I'd like to do a -10an adapter no thermostat and -10an inlet/outlet on a cooler as soon as I find what I need.
In az I'm not sure I need the thermostat
03spoolindmax
Nov 9, 2011
674
Mi
Earls recommends a thermostat. They state if you don't have a thermostat and the engine/oil is cold you could blow the cooler out if you get on it or spike the oil pressure. Being in az though you might not have a problem
610
really?!? i think that rep needs to go through a fram course again... stock pressure maxs is less than 90psi with a cooler pressure tested to at least200 psi
the problem with sandwich adapters is the make very sharp90* turns that result in pressure drops
03spoolindmax
Nov 9, 2011
674
Mi
I was just stating what was sent with the cooler. I wondered myself how it could cause the cooler to burst but haven't had any issues.
diesel53
Sep 16, 2010
907
AZ
Are you talking the internal angles? Or fittings your the lines leaving the adapter?
