08 fuel filter problems
Rylanrussell
Nov 1, 2014
I was replacing a fuel filter yesterday on an 08 lmm and I got the fuel filter to fill half why up. The it stop puting fuel in the filter what should I do thank you
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
No need to fill the filter prior to installing (not recommended), install the filter then loosen the bleed screw on the primer pump and pump till the fuel comes out.
Rylanrussell
Nov 1, 2014
I already did that I did not pre fill the fuel filter. The fuel filter pump filled it up half way then stopped pumping fuel in to the filter
Rylanrussell
Nov 1, 2014
PLEASE help fuel filter
I replaced a fuel filter on an 08 lmm. The fuel filter got half way filled up from the fuel filter pump then stopped pumping the fuel in to the filter. What should I do need help fast thanks
:confused::confused::confused:
9,903
149
So if you take the filter off and pump it does it move fuel freely?
