Been having tons of problems this weekend with my truck. It's a 2006 LLY ("lbz"). I ordered Efi live from ATP. Friday evening I started working on the truck, stayed up all night doing the egr delete, pcv reroute, and down pipe. Saturday morning around 7, I decided to upload my Efi live. It went through step one fine and saved the stock tune, did the licensing, and started uploading the tune to the truck. It got around 70% and the $0281 error code popped up. (ATP described this code as an error in communication. I.E. Low battery or connection at the obdII port or autocal came loose, neither of which happened.) Tried reloading the tune and instantly the error pops up again. Yes I have the key in the correct positions. Tried several more time with no luck. Called ATP and they had me disconnect both batteries for 30 minutes and put a charger on the batteries but that didn't fix anything either. Now the truck will not even crank over. All lights and accessories work fine, truck just won't start. Before doing the Efi live, I started the truck and drove it around the block and it was fine after doing all the egr, pcv, down pipe stuff. While doing the egr, pcv, and down pipe, I had both batteries disconnected. The grid heater power wire arced on something when I disconnected it so figured I may as well disconnect the batteries while I did all the work. So both batteries were off the truck for 8 hours or so. Both batteries are currently putting out 12.25 volts. All connections are good. No fuses are blown. Now I have the VATS light on the dash (car with lock on it). Tried doing the unlock, cycle key to start, leave on run for 10-11, do it again etc. with no luck. The vats light never actually goes out after the allotted time frame of 10-11 minutes. Even waited up to 15 minutes for it to go out and nothing. Also read someone said leave the key on for 30 minutes straight and it may go out, currently doing that as I type this. ATP says the ECM may be fried?? And that I need to send it in for them to bench test it. Unfortunately this is my only vehicle currently, have work tomorrow at 4am and I'm running out of options. I also plugged the Autocal into my computer and did the firmware update. Didn't fix anything. I've checked everything I can possibly think of. Truck was fine until the Efi live was plugged in. The vats light is on which makes me think oh I'm just locked out, but the truck should still crank over if it's vats right? I have nothing at all. Oh I also read aftermarket radios can effect it, tried pulling radio fuse and that didn't help either. So in a nutshell, Efi live throws error code $0281, vats light on, won't crank, batteries are good. Can anyone help? Any additional info needed? Anything I should check? Please help! Thank you!
