Hi friends. I have an '06 lly that has some ecm/ecu issues.
The engine will start itself while sitting still. I first noticed it after driving through a hard rain which makes me think its a matter of the computer getting wet and short circuiting. I disconnected the batteries for a little while and after sitting for a couple hours I reconnected them and things were fine. That problems has evolved into a constant issue though (wet or not) so these days when the batteries are connected, the starter will engage and the engine will run (sometimes poorly) until i disconnect the harness at the ecm.
More recently, it is having security issues. The engine will start, run for a minute, and then stop (with the security light flashing on the dash board). After a couple of starting cycles it will usually start and run (but the security light will either stay on or flash) but it will stay running until I disconnect the ecm.
Does anyone know how the ecm turns off the engine? Does it cut power to the FICM? Or perhaps the FPR? I'm looking for a bypass method for testing purposes. In theory- if it works that way, I could supply power to the FICM or another administrative device and keep it running, or turn it off while isolating the ecm issues.
Thanks for the help!
