05 AC problem
03GreenLB7
R-O-C-K in the U.S.A.
Jan 16, 2009
222
Pittsburgh
Ok, my ac used to work fine. My truck is an 05 and has the digital Heat n AC. Today me and my brother installed a dump bed insert on the truck, had the passenger side battery disconnected for maybe 2 mins, if that to put the battery cables for the hydro pump on the dump bed insert. now, when i started up the truck, it went straight to auto 74*. then the driver side blows hot air, when set to any temp. the Passenger side works fine. Somebody help me out?
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
try unhooking the batteries again and see what happens. I have heard there is a relay/switch or whatever that will get stuck one way sometimes when the batteries are out. Happened to my dads avalanche all the time.
03GreenLB7
Jan 16, 2009
222
Pittsburgh
well, my brother called me right after i posted it, said he did some checking around and to pull the fuses for the hvac. let it sit with them out for a minute, then start the truck, and let it sit for a minute, it fixed everything.
before i posted we tried unhooking the batteries several times. thanks for the input
