Got a friends all stock 04 LB7 277k and she just quit running. started running a little rough (NO SMOKE) then quit. changed fuel filter/primed/new rebuilt filter head.. still nothing. No codes or nothing.
Ive been looking at all of the hard/no start theads and everything that people have found out is still good on this truck.
-Absolutly no smoke out the tail pipe while cranking
-the EDU fuse is not blown or any other fuse.
-swapped EDU relay also
-bale connector wires and wires by FICM are not chaffed
-even checked under the fuse panel for wire chaffing/connections
-Tryed different FICM still nothing
-Has Cam and Crank signal present while cranking
-has 4500-5800 rail psi while cranking
-cranks at 185-205 rpm
-efi live says 1.9-2.1 mil.sec. for all the injectors
-Has an Edge/attitude BUT i unplugged it so thats out:thumb:
-it gets plenty of fuel to the filter/plunger is hard
-it has never had an extended cranking problem...so i dont think return rates are a problem.
-and it cranks unusually fast, that the exhaust hits something under the truck
- im sure i didnt mention some other things that i tried but these came to mind at the moment.
So as you can see im just about out of ideas
Any help would be awesome.
Thanks,
Joe
Thanks,
Joe
