I'm really hoping to get the help I need here. The problem I'm having is recently when I drive my truck into work which is an hour away, when I come to a stop I go into Limp Mode. I have an Edge programer so I looked at the codes, I'm getting a p0101. My air filter is about a month old and it was clean. I used some MAF Sensor cleaner really good, and put it back on. I start it up and get to driving and when I come to a stop at a light, it goes into Limp Mode. I used to be able to shut my truck off for a minute or two, clear the codes and away I'd go, but it's getting worse. Here's some things I've taken note of, My Vanes usually at idle, are closed to about 88-89%. Since my p0101 issues, I've noticed when I come to a stop my Vanes drop to 0% and stay for a while, then fluctuate and my MAF g/s goes from 30-40 down to 17 g/s when that happens. I came to work this morning and decided to give it a little gas when I had to stop at a light, keeping it under load. My truck didn't go into Limp Mode when I did that. Can anyone help me troubleshoot this one so I don't go and dump a bunch of money on a new MAF Sensor or Turbo rebuild kits, or the hundred other things it could be? Thanks in advance!
-Brad
-Brad
