I just picked up an 03 duramax that was in need of some TLC, ecsb, what I am thinking I want to do is put a 72ish body on this frame and make it a single cab short bed. I know this has been done several times and I have looked at several threads but have a few questions about it.
1. I want the interior of the truck to apear completely as a 72, but want the AC, cruise etc to still work. I don't want the steering column or gauge cluster. Can these be removed and still have the rest work? Any ideas on this
2. I don't believe I need a standalone as the entire truck is there and I still want ABS and everything to function normally, any thoughts? I think this also ties into the previous question on the column and cluster delete. I could possibly even splice in to the factory power windows and door locks and make those work in the older truck.
I want to tie the wait to start light to a factory idiot light and make that work and get a check engine light the same way. And an OBD port hidden somewhat under the dash
Gauges shouldn't be a huge problem to make work just put sending units in off of the older motor and wire up basically. Only issue I see is figuring the tach and cable driven speedo out on the factory gauges but that shouldn't be a huge hurdle.
Anything I am missing on the electrical side? The fab side I will figure out as I go, plan on using the radiator and CAC out of the 03 as well as most of the core support modded to fit the older body.
