Allison 5sp: 03 trans in an 02
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I think the trans fittings are 3?4 on the 02 and 7/8s on the 03. They did make some 03s early with the old trans and later they were the same as the 04 trans I think there is a cut off date. Check the tag on the trans for a manufactures date.Otherwise I'm sure Mike L will know.
15,681
Maybe nothing needs to be changed. Early '03 had the same fittings as '01/'02. Later '03 had the same fittings as '04/'12. If your '03 is a late one you need only goo to chevy and buy the adapter fittings. All Allison factory remans only come with late bell housing and adapter fittings.
