03 pass door locks and window not working
Cougar281
1,830
268
St Louis, MO
Check the MBEC maxi-fuse under the hood. If that's blown, replace it and see if it works. Took me a while to figure it out, but every time I pushed the e-brake down hard, the MBEC fuse would blow and the passenger side would stop working. If that's it, pull up the carpet under the e-brake and look for a wire bundle. Inspect it for pinching or arcing. Move it out of it's original path so it doesn't get crushed when you push the e-brake.
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
www.larrysperformancepalace.com
So far we were told pass ft door locks, windows nothing works. will not get the truck now till tuesday. I guess something came so wont know till then. thanks for the help though. I willl follow up with a fix as this seems to be a common issue.
