so this started happening before i even built the tranny but has only got worse since. it come up range shift inhibited and will clunk as u go from reverse to drive. sumtimes ull have to shut it off and it will go into gear when u restart. put a new NSBU switch on rodded it around shut if off restart a few times and it was going into gear came back out 15 min later and here we go again! noticed the connectors were kinda gunky cleaned up a lil, used hair dryer on the glue plugged em bac in. took the connectors off the tcm and blew with air then re installed. could it b the pressure switch? once u get it into gear it runs fine until u shut if off and try again.
