I've got an 03 lb7 that is perfectly fine one minute then gives me problems the next. Issues I'm having are when I start the truck the gear selector indicator light doesn't come on. When I put it in gear the truck limps to 3rd and the Speedo doesn't work, which as far as I know is causing the trans not to shift. Lastly when I hook up my solus it will connect to everything but the trans.. If I leave the truck sit and go start it again everything will be just fine and I connect the scanner and there are no codes. Hopefully all that makes sense and any help or ideas are appreciated.
