03 gmc 8.1 starts then dies, PLEASE HELP
Foxtrott4646
Jul 12, 2018
21
25
Reno
The truck starts for less than a second with no problem before dying with a display message of "BATTERY NOT CHARGING" truck wont run long enough for me to test alternator, but battery has good power so I figured it should at least run for a little off the battery but to no avail, im going to take the alternator down and get it tested, but I still don't see why it wouldn't run off the battery
Sent from my SM-G988U using Tapatalk
3,727
296
The "battery not charging" message is probably because the engine died, not why it died. The alternator might be fine.
You'll need to check the basics:
* Security (does the security light go out or stay on, etc.)
* Fuel pressure
* Etc.
Sent from my ONEPLUS A6013 using Tapatalk
1,068
I believe those were notorious for cam or crank sensor issues too. IF you have a capable scan tool, see if shows the signal while cranking to rule that out.
