'03 ECSB: Unknown vibration while driving
BARBER
Farm Truck
Jul 17, 2013
62
Owanka, SD
On my '03 ECSB with 170k on it, I got a vibration that comes from it whenever I'm on the highway or interstate. It always starts in at about 75 or 76 mph and does it all the way up to the low 80s and if you go even faster up to 85 or more, it goes away. And whenever the vibration comes on, it does it when the pickup is under a load, such as accelerating up to speed or pulling a grade/hill. It goes away when you're coasting and comes/goes when you're on a level drive. Does it sound like a U joint or is my rear driveshaft out of balance. I know at some point both the rear U joints have been replaced. I haven't taken the time to pull the rear differential cover off to inspect the diff and change the fluid. It couldn't be a front hub, and somebody correct me if I'm wrong, because it would be making more of a grinding noise right? Any help is appreciated.
cwmeaux1
303
41
Carlyss, Louisiana
We had one doin , same thing . Broke drive shaft at track 2wd. So we changed , cracked motor adapter plate , drive shaft, u-joints , rear trans bearing , had trans inspected, rear yoke , studded motor mnts , one front wheel bearing ,balanced and changed tires , ended up being in rear end , :(
BARBER
Farm Truck
Jul 17, 2013
62
Owanka, SD
When it was previously serviced, everything underneath was visually inspected and checked. Would be wise to pull the diff cover and check to see if there's anything wrong. I know my G80 works fine.
