02 lb7 fuel issue
eutsey04
Gearhead
Mar 22, 2013
51
Scottdale pa
Ok mad scientist got a problem with my lb7 I've been havein a problem with it startin when it's warmed up it starts up fairly easily but when it's cold it won't start so I was told try a lift pump so I put a lift pump on it today and still same problem I had new o ring in fuel filter head with aluminum bleeder screw... helpppppppp should I take the fuel filter off completely n run a new filter system after the pump or what should I do???
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
How old are the batteries?
Are you seeing the wait to start lamp?Are you waiting?
Have you scanned for codes?
You mentioned a lift pump have you lost prime as in wont start you prime it starts?
Have you tried plugging it in?
How cold is cold?
That should keep you busy ! :D
