I have a 02 Silverado 2500 HD with a 158000 miles on it . A couple weeks ago I stopped for something to drink . I came out and I had oil dripping off the front of the engine . So I towed the truck home and drained my oil . I figured I had a stuck injector . So filled the crankcase up and put some purple brands injector cleaner in the tank . Truck smoked blue or gray smoke after start up and and as I drove it started going away . . Thought okay it's fixed ? Drove it a couple days to work but in the back of my mind I wondered . So I checked the computer and got a P 1093 code low pressure . Cleared it and a few miles later it came back . No check engine light . So I drove it another day but my oi pressure would start out above 80 and as it warmed up it would drop to under 40 lbs . At idle it would go to 20 lbs . it would never go below 45 any time .So I worried I had diesel in the oil again . I didn't have time to work on it and wasn't sure where to start . So I took it to a garage here in town . Called them today to see how and what was going on . Was told there is an injector leaking . Not sure which one ? They left the truck in the shop during the weekend and it had a puddle of diesel under it a foot in diameter . The crankcase has diesel in it . Now the reason I started this post is because is because I have read the stories of guys replacing injectors and 30 or 40 thousand miles doing it again . I have also read where the expense was just as much as replacing the engine . That was recommended instead of doing injectors . I work on Diesel engines for a living but I am unfamiliar with the duramax .I also have no way to do the checks for fuel pressure and volume . I could do the work but I don't want to have to replace the injectors for a long time . So my question did Gm have a better injector made for the newer engines and will they work in mine . Does somebody out there rebuild or make a better injector then GM ? Cost also is what I am worried about ? I have read estimates in the thousands ? So I need some advice . Thanks for reading
