Ive got a bunch of the parts n pieces already
The LB7 / Allison combo is from an 03 GMC 2500 HD 2wd Crew Cab... I will convert the trans to 4x4 & put the speedo sensor in the 4x4 adapter because Im gonna run doublers... 37in Hummer Baja Takeoffs on old school 16.5x9.75 slot mags... Axles will be a 78/79 Dana 60 high pinion kingpin & a 14 bolt rear out of a mid 80s Military K30 for the 4.56s & Detroit Locker... Its gettin 4 links at both ends & itll be on Air Bags
I figured I better post up because Im already needin info on Wiring!!! I wont be using the ABS Stuff soo I need to know what the connector pinouts are on the black 20pin... Theres a purple wire that came from the brake master cyl. To the 20pin & I need to know Where to Relocate that one... Then theres another purple & a black with white stripe wire... Both of those trace to the red block under the fuse panel thats under the hood... Other than this I dont see any big speed bumps because Im usin all the wiring from the Full Size & the Steering column too itll also get the HydroBoost brakes snd a Reseal Kit for that... The LB7 needs SAC 45s & a pinned water pump from the start... Soo IF Yall can help with ABS connector pinouts & any wiring diagrams so I can make the stuff workRight after the Delete Thanks In Advance!!!
