2006 LBZ CC/SB 4x4, long horn trac bars, full cognito steering and braces, MA idler arm bracket brace, transfer case pump rub kit and brace, stage 5 suncoast kit goerend PTO covers and case drilled for C3, billet C2 hub, ATS triple lock converter, cam and crank machined for keyways, brian crowler billet rods, mahle bearings, mahle cast performance pistons, RDP manifolds and up pipes, HSP twin turbo kit with S475 over stock batmowheel, All hot pipes wrapped, ported rail fittings, race plug, larger CP3 fuel fittings, industrial injection duel CP3 kit and %30 over nozzles, Airdog 150 lift pump.
