LB7 shortblock built by BMS Machine, Howard's rods, cut pistons to 16-1, DPR HV oil pump, stock cam and heads,LLY top end,MPI twins, kennedy dual pumps, Cognito braces, SD sleeves, spring clamps, SC III, straight pipe, Rhino liner, Ultra 18" rims, EFILive DSP5, Autometer C2 boost, EGT and oil psi on a-pillar, GFCIs on B-pillars, shimmed FPRV, All Season Eaton rear end, Westin nerf bars, 5% tint all around, custom badge from billetbadges.com, painted taillights/3rd brake light, Recon Xtreme light bar, all headlight on mod, shaved antennae mod, fumoto,Bilsteins, Banks super scoop and CAC pipe, RENO's tcase brace, Kennedy tcase fix. Relocated FICM (dry), removed EGR canister, Built in memory of my late brother, Brody.
Named:
GRIM REAPER DURAMAX, BRODY EDITION
Named:
