S366/480 mpi twin turbo kit w/ billet wheels and polished race covers
Fully built motor- carillo rods, socal cam, radys gorilla girdle, mahle .20 over pistons, ground/ polished and renitrited crank with keyways,ARP main and head studs, so-cal injector stud hold down,so cal super dampr, mike L trans cooler, banks intercooler, merchant trans lines, ppe pitman idler support kit, cognito upper control arms, bilstein 5100 series shocks,merchant welded pump, ppe deep trans pan and rear dif cover,so-cal flex plate, PPE duel fueler, airdog lift pump,Fleece tapshifter conversion, PPE oil centrafuge kit, PPE race manifolds and up pipes,100% over ddp comp nozzles, randy's stage 2 heads with screw in cups, merchant automotive motor mounts, traction bars, t case support brace and pump rub kit,ARB air locker, ppe stage V trans, PPE coolant tank, katzkin leather with bose center console conversion, edge insight cts with iss pro EV2 boost and pyro, PPE over head gauges, Boost and rail pressure. Ppe high idle/ valet switch, ppe HIDs, 20x10 fuel hostage wheels. Underground orange powdercoat.
Extreme Prejudice Racing efi live and trans tuning.
