Busted links
5,098
I’ll have to look at it when I get time on a computer. The links work in Tapatalk but I’ll check on a computer as well
buick455
55
I actually find that to be the case with many of the old links, not just in that thread. I don't use tap talk.
5,098
^^ it is. ive got to dive into this more and see how to fix it. use to be no fix but since Xenforo has been out for more time now, guys are coming up with fixes, just need to find the one that works for us.
5,098
alright, ive got an idea on how to fix broken links.
It will easiest if you guys either just report the post with a little description. If i get a ton of reports on the same post, ill figure something else out but i dont forsee that as an issue.
in the mean time, links are fixed in the thread you asked about, @JoshH. the formatting in Henrys are is screwy as ive not had time to dive into the LBZ area but hopefully i have some time sooner than later for it.
Reactions: JoshH
5,098
What are the chance you can fix the old DTC thread... I guess the old formatting didn't cross over?
They were all screwed up and mainly copy/pastes from gm's site. i tried to clean alot of them up, specifcally the engine models but ive since lost access to GM's site through my buddy that was a tech for a dealer.
if there is a place online that has it and we can copy/paste, i can update it.
its all old java script stuff so we were going to be SOL regardless of the forum i picked when upgrading/updating....
1,817
is it possible to just copy over the relevant text from their site so we can avoid the constant changes of the links GM likes to do?
833
James, when you get a chance, can you work on the link redirects in this thread?
Reactions: Gentrysgarage
5,098
Done!
9,903
149
Not a busted link but the pics don’t work for me in the FPRV thread in the DIY section anymore.
LLY P1093 Shim Mod Instructions: is the title.​
