  #1
Old 12-30-2008, 07:18 PM
01 crew 01 crew is offline
FNG
Default dead pedal
when i tow my toy hauler between 2500 and 2800 rpm i get dead pedal for 30 sec or so and then power comes back. usally no codes twice got engine overboost. dealership says its my exaust b.s its a 4" magnaflow.i read on this forum someone said they could flash the computer to 02 and it would help if any info im desperate thanks
  #2
Old 12-30-2008, 07:36 PM
Turbo Buick 6's Avatar
Turbo Buick 6 Turbo Buick 6 is offline
Default
Fill out your sig so that other know what all is done to your truck. A log of this with EFI could help.
Welcome
__________________
4.5 CLUB
Member #2
06 2500HD LLY reg cab 4wd
Ever feel like lying, down inside a grave
Listen to the elegy, a buyer of the hate
Ever dance beside the devil, taste the barrel of a gauge,
Ever pull the trigger, the light begins to fade
Feel like slipping away
  #3
Old 12-30-2008, 10:56 PM
Darius6t9 Darius6t9 is offline
I'm the Floater. Lurking.
Default
I'm going to guess it's a 01' Crew cab. And I agree, No way it exhaust.
  #4
Old 12-30-2008, 11:38 PM
FNG
Default dead pedal
sorry havent done sig yet 01 crew cab 4"magnaflow hypertech programer not much
  #5
Old 12-31-2008, 05:44 AM
TheBac's Avatar
TheBac TheBac is offline
Default
My opinions:
1) Try going back to stock tune first. It could be something in the Hypertech tune causing it.
2) Check for codes. Could be Throttle position sensor, maf or something else.
3) Wiring from throttle could be grounding out intermittently.
4) Others have suggested checking air or fuel filter, but I dont think its that.
__________________
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
2014 Chevy Cruze Diesel -- the DD
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
From mufflerguy on yb,
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!"
  #6
Old 12-31-2008, 10:54 AM
FNG
Default
it does the same thing without programer .i have only had a code twice and it was engine over boost most the time it does it there are no codes.changed filter and dealer has upgraded the injectors its crazy.
__________________
01 crew cab 4"magnaflow hypertech programer 285s
  #7
Old 12-31-2008, 11:04 AM
TheBac's Avatar
Default
Did it do it before the dealer serviced the injectors?
__________________
Tom
12.14@111.15
  #8
Old 12-31-2008, 11:10 AM
FNG
Default
yes it got better i could run my programmer in stage 2. now it will do it without again.
__________________
  #9
Old 12-31-2008, 04:08 PM
whitetrash21's Avatar
whitetrash21 whitetrash21 is offline
put on da damn helmet day
Default
TPS wiring has a bad ground??
  #10
Old 12-31-2008, 05:21 PM
FNG
Default
have you heard of this before? that sounds fun to find
__________________
  #11
Old 12-31-2008, 07:01 PM
Default
Quote:
I have, but it involved a quadzilla programmer, not hypertech and not a sstock truck. Like jon said, I'd check your TPS wiring. A bad ground or loose connection could cause something like this....
I know the NSBU can cause some funny issues, not sure if this is one of them or not.....
edit: any codes??
  #12
Old 12-31-2008, 11:16 PM
GMC_2002_Dmax's Avatar
GMC_2002_Dmax GMC_2002_Dmax is offline
The Still Master
Default
GHOST PEDAL,
Common 2001 OS problem once a programmer is used.
Some of them corrupt the OS when trying to remove the top speed limiter.
A 2002 OS upgrade is all you need and problem will be solved.
Let me know if I can help.
Tony
__________________
2016 Denali LML----> 2012 Denali LML SOLD
2007 GMC "Classic", LBZ, SLE1 ,RC/LB, 4x4
~Powered By "MOONSHINE"
12.525 at 107.07
2002-GMC Sierra 2500HD SLE/CC/SB/4X4~Powered By "MOONSHINE"
12.65 fuel only, 12.00 on some N20
Retired 04/18/2009...................SOLD 01/2014
  #13
Old 01-01-2009, 02:02 PM
FNG
Default
i would love some help my # 559-333-6364 adam thanks
__________________
  #14
Old 01-03-2009, 03:48 PM
FNG
Default
just wondering if any one else has heard of dead pedal or ghost pedal ? i think gmc 2002 dmax might have a soulution waiting to hear back thanks for your input ,guys
__________________
  #15
Old 01-03-2009, 03:52 PM
specialagentPK's Avatar
specialagentPK specialagentPK is offline
Default
If you tell us where you are there may be someone in your area with EFI Live that could throw a 2002 OS in your truck.
__________________
2001 GMC 2500HD
BD-Power 4" Duals
EFI Live V2
AFE Stage 2 Intake
Suncoast Stage 4 Tranny & McRat Converter- Special thanks to Mike L.
HTT Turbo
FASS 150GPH
530hp and 1000 lb.ft daily driver
Max Dyno 569hp and 1260 lb.ft
Tuning by Adam(Malibu795)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
