  #1
Old 11-30-2008, 04:52 PM
NWTDIESEL NWTDIESEL is offline
On a Time Out
Default How to unlock the anti theft security?
I think thats whats causin my truck from starting wit the key. How the F do i unlock it??
  #2
Old 11-30-2008, 05:00 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
Try the emergency relearn?
http://www.duramaxdiesels.com/forum/...ead.php?t=2035
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #3
Old 11-30-2008, 05:10 PM
On a Time Out
Default
So you think my ecm is fried? I read the link to DP. I have one of Tonys moonshine ECMs in my truck rite now. I dont want to mess it up, i just want to unlock the security option. The dash is showing a pic of the truck with a lock thru it.
  #4
Old 11-30-2008, 05:17 PM
Alligator Alligator is offline
Default
Newly, it might need to be reflashed at the dealer. That happend to my dad's 05 and it needed to be reflashed to fix it. The emergency re-learn got my dad's truck restarted and to the dealer, but not mine, my ECM needed to be replaced...
__________________
2006 CC/SB 4x4 LBZ Built - 900hp tow rig
2006 SC/LB LBZ Built - Caged
2002 SC/LB LB7 - 500hp parts getter
Team Borrowed Time #15
  #5
Old 11-30-2008, 05:19 PM
Kat's Avatar
Kat Kat is offline
Default
Quote:
As far as I know it won't hurt tune.
That is how people can sell TTS extremes
__________________
  #6
Old 11-30-2008, 05:31 PM
On a Time Out
Default
Ok, thanks guys. Im counting down the 11 mins rite now so ill let you kno in 33 mins if it starts.
I have another ECM for my truck that is unlocked but it 50 mi away. The RR ECM in it now is locked... MMLMM just informed me i cant do anything with EFI to fix it since its locked.
  #7
Old 11-30-2008, 05:42 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
Newly thats not your problem.
If it was a security issue the truck would still crank. It just would not fire.
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #8
Old 11-30-2008, 05:44 PM
MMLMM's Avatar
MMLMM MMLMM is offline
Default
someone elswe might know if you can access anything via efilive with a locked ecm. i didnt think you could. also not sure if disabling the vats will even help.
also newly said if he jumps the starter it will run normal with no security light....
__________________
2002 LB7 EC/SB
Fleece Cheetah, ARPs, LBZ CP3, Built Allison, AirDog 165, Tap Shifter, EFI Live Custom Tuning By Me, Lowering Shackles,
Original Toyo Proxies on 20" XD Spy's, S&B Intake, MagnaFlow DP & 4", and a few other gadgets and appearance mods
  #9
Old 11-30-2008, 05:50 PM
On a Time Out
Default
Yea, your rite. Tony just pointed that out to me. I tried it anyways and it didnt work....... Why would my truck run fine, shift fine when i jump the starter?? It just wont start and turn signals + few instruments dont work.
  #10
Old 11-30-2008, 05:57 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
Did you check ALL your fuses with a test lamp (not visually)?
Also check the pins on the Bale Connectors for pushed-in, bent, or corrosion.
Yes, the VATS will let the truck crank for a few seconds then stop.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #11
Old 11-30-2008, 06:03 PM
On a Time Out
Default
I used a test light to check all the fuses. All the pins seem to be fine. I left my truck at my parents house for 2 1/2 months. They started it every week and let it warm up. When i got home i cycled the glow plgs 3 times then started it up just fine and let it run/high idle for 1-2 hours (its 19* here) so it could warm up. After i shut it off, BAM!!! it wont start now.
  #12
Old 11-30-2008, 06:06 PM
McRat's Avatar
Diesel Hotrodder
Default
NSBU? switch OK?
__________________
Pat and Kat McSwain
  #13
Old 11-30-2008, 06:14 PM
<--- slippery roads
Default
corrosion on the ECM pins..?
__________________
  #14
Old 11-30-2008, 06:15 PM
On a Time Out
Default
NSBU? switch OK?
How do i check it? My gear shift light indicator is working fine. Ive had NSBU replaced twice already. IDK what to do?
  #15
Old 11-30-2008, 06:18 PM
On a Time Out
Default
Im gonna eat dinner and head down to Farmington (50mi)to get my other ECM. Ill replace that tonight and clean the ECM pins. Im lost with this think and getting
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
