  #1
Old 11-04-2008, 07:08 PM
Gmclbz's Avatar
Gmclbz Gmclbz is offline
Default Injector Removal and Install
I am going to be installing larger injectors as a winter project and was just looking for a little advice. Truck is an 07' Lbz. I will probably have mine sent out and have them extrude honed (not sure who yet). Is there anything major to watch for or is it pretty simple? Also just curious how much time would be needed for removal?
Thanks, Jim
__________________
11.57@116
7.31@94
  #2
Old 11-04-2008, 07:10 PM
Jared Duramax's Avatar
Jared Duramax Jared Duramax is offline
<---- $$$ Whore!!
Default
yours is easy compared to an LB7
Just make sure you work clean and dont drop anything in the cylinders Good Luck
__________________
Jared
2003 GMC Sierra 2500HD LB7
  #3
Old 11-10-2008, 01:07 PM
Gmclbz's Avatar
Default
How about time? Any idea how much time for removal. I'm just curious
is all.
__________________
11.57@116
7.31@94
  #4
Old 11-10-2008, 01:16 PM
<---- $$$ Whore!!
Default
i couldnt see more than a couple hours to do it but that really depends on the tools avalable.
i wish i would have gotten an injector line tool so that i could put a ratchet on instead i used a flare nut wrench and i banged my hands a few times
Ill try to get you a part number for the injector line tool
__________________
Jared
  #5
Old 11-10-2008, 01:47 PM
Cougar281's Avatar
Cougar281 Cougar281 is offline
Default
I think it took me 3 or 4 hours to remove and swap two injectors (#5 and #6)... With a trip to the dealer for the gold-plated O-Rings. Getting TO the injectors was actually harder and more time consuming than actually getting them out.
You WILL need new O-rings (My O-rings came out broken; I woulnd't suggest re-using them regardless of the age), and should probably replace the copper washers. They're both about $8!
__________________
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
  #6
Old 11-10-2008, 02:03 PM
Gmclbz's Avatar
Default
Thank you very much guys, this is what I was looking for. I kinda figured o-rings should be replaced. Are they a dealer only item?
Jared if you could get me a part # that would be great...
__________________
11.57@116
7.31@94
  #7
Old 11-10-2008, 02:53 PM
<---- $$$ Whore!!
Default
here is the part number OTC7453A but by the price you may just want to deal with getting some smashed fingers but an LBZ may be completly different than a LB7 and not as difficult to work on
__________________
Jared
  #8
Old 11-10-2008, 04:42 PM
RENODMAX's Avatar
RENODMAX RENODMAX is offline
Dead Wrong
Default
LB7 injectors are a PITA LBZ are easy breezy
__________________
2014 Silvy 1500 CCSB- mostly stock fishing rig
2004 LB7 CCSB
Built trans, tuning, fabbed stuff by me- SOLD
  #9
Old 11-10-2008, 04:53 PM
WolfLLY's Avatar
WolfLLY WolfLLY is online now
Making Chips
Default
It should only take you about 3- 4 hours to swap all of them. Just make sure you clean everything
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #10
Old 11-10-2008, 07:27 PM
Gmclbz's Avatar
Default
Quote:
Thanks guys....
__________________
11.57@116
7.31@94
  #11
Old 11-10-2008, 07:29 PM
<---- $$$ Whore!!
Default
Quote:
thats good to know
__________________
Jared
  #12
Old 11-10-2008, 11:01 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
thats good to know
Is it Doesn't seem like it to me
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
  #13
Old 12-10-2008, 09:23 PM
Alligator Alligator is offline
Default
You might also make sure you don't drop the little wafer that is at the top of the needle. If you lose it, it will cost you an injector. It is the size of a ball point pen. Make sure you have no distractions when doing it.
__________________
2006 CC/SB 4x4 LBZ Built - 900hp tow rig
2006 SC/LB LBZ Built - Caged
2002 SC/LB LB7 - 500hp parts getter
Team Borrowed Time #15
  #14
Old 12-10-2008, 09:38 PM
03 D-max's Avatar
03 D-max 03 D-max is offline
Honorary "Tosser"
Default
thats good to know
no it isnt that sucks for me i need a tranny and cp3 before injectors anyway
__________________
JACOB
Post Whore want to be#1
Easter Whore Member#2
Team Borrowed Time Member#23
Quote:
Originally Posted by The Neens View Post
I don't spray much...Usually only after Mexican food
03 2500hd Efi Live, SD, PPE, FASS, MBRP, K&N
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
