  #1
Old 04-09-2007, 04:58 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default Drive shaft pics
This is after I welded it back together. Sorry no pics of it broken.
Upon inspection the factory wekd had poor tie in on the yoke. Well I fixed that
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #2
Old 04-09-2007, 05:02 PM
WolfLLY's Avatar
Making Chips
Default
Another angle
__________________
LB7 ECSB 4X4
  #3
Old 04-09-2007, 05:14 PM
ecc_33's Avatar
ecc_33 ecc_33 is offline
Junior Member
Default
hope it holds better this time for ya
__________________
02 extra cab long bed
Thanks: CRANK IT UP DIESEL PPE ATS SUPER DIESEL MCRAT RACING
CREATURES OF THE NIGHT BES RACING
Carrillo rods, Hamilton valve springs, ATI damper, 60% bigger nozzles, head studs, S475 turbo, 4inch lift kit, ATS dual fueler, ATS Tranny,Bunch of SD parts,lobonte water injection, AD 165gph,
best time 11.63 at 116 49,200 miles
  #4
Old 04-09-2007, 05:43 PM
JoshH's Avatar
JoshH JoshH is offline
Default
Looks good. How did you weld it? Did you weld it with the u-joint in place or did you remove it during welding?
  #5
Old 04-09-2007, 06:38 PM
02freighttrain's Avatar
02freighttrain 02freighttrain is offline
Team Salad Bartender
Default
Purdy weld'in. That should hold. Did it fracture or did it just look marginal?
  #6
Old 04-09-2007, 09:39 PM
turbo-max's Avatar
turbo-max turbo-max is offline
WaaaZaaaa
Default
mig,or tig? although it looks to be tig welds to me.
__________________
Jeff ~turbo-max
Turbo Lag is a courteous head start.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
02 GMC Sierra 2500HD CCSB 2x4 6.0L gas
05 silver-a-do 2500 HD ext cab 4x4 * gone *
96 dodge ram 2500 ext cab 2x4 cummins gone...got the HELL outta dodge
"team salad" and defender of the McRat Universe
to the McSwains
  #7
Old 04-10-2007, 08:26 AM
MaxFarmer's Avatar
MaxFarmer MaxFarmer is offline
<--Heavy Smoker
Default
I just wonder how you made sure you had it back square? My luck the weld would pull it off some and it would wobble like hell!
__________________
----Jason----
'01 LB7, EFI Live, SoCal Stage 1 Heads, BD Man, KD 4" SS Exhaust & Dual LP's, SD centerlink, Trippin Billet Fuel Pickup, Cognito pitman/idler stiffeners, Beefy Tie Rods, PURPLE SCIV, 1058 TC, Mike L trans cooler & Snake Oiler, Full Transgo, NEW Co-PilotATS 75 hp Sticks, Suncoast Transfer Case Brace, High Idle, Eaton E-Locker, AAM (Torsen) Rear Diff, 305/75/17 BFG's, OS #15188873
Proud Member of Team Salad!
Mid-Whore #1
  #8
Old 04-10-2007, 10:09 AM
JoshH's Avatar
Default
Quote:
I was thinking it looked an awful lot like TIG welding myself, but I didn't want to make any assumptions. Either way it looks good.
I just hope you didn't melt the seals on the u-joint or burn the grease out if you welded with them installed.
  #9
Old 04-10-2007, 10:19 AM
BigWill_21's Avatar
BigWill_21 BigWill_21 is offline
~BULL HURLEY Look-A-Like~
Default
It' looks like the factory u-joint!!!
Wolf.. Be sure to change that bad boy, the heat killed th eseals and grease!!!
BTW: Nice burn on those stacked dimes!!! I wish I could lay down beads like that!!!
__________________
2004.5 - GMC 2500HD X-Cab/Short Bed - EFILive courtesy of McRatRacing.com, Tuned by "The NEENS" , 4" MBRP, 285 BFG M/T's
2007 - GMC 2500HD Crew/Shortbed - STOCK... For now!!!!!
  #10
Old 04-10-2007, 10:24 AM
turbo-max's Avatar
WaaaZaaaa
Default
i'd be willing to bet the joint never got very warm like you guys might think, nice thing about tig welding....
__________________
Jeff ~turbo-max
to the McSwains
  #11
Old 04-10-2007, 10:36 AM
WolfLLY's Avatar
Making Chips
Default
I tig welded it. The joint didnt get hot.
The CMM showed me that I had it square.
__________________
LB7 ECSB 4X4
  #12
Old 04-10-2007, 10:38 AM
WolfLLY's Avatar
Making Chips
Default
Quote:
It broke in half. The factory weld didnt tie in to the yoke at all.
__________________
LB7 ECSB 4X4
  #13
Old 04-10-2007, 11:43 AM
turbo-max's Avatar
WaaaZaaaa
Default
Quote:
that means the guy that welded it had a short whoo-ya deal (no penatration)
__________________
Jeff ~turbo-max
to the McSwains
  #14
Old 04-10-2007, 12:16 PM
JoshH's Avatar
Default
I really need more practice with a TIG machine.
I don't want to step on your toes or anything, but did you make sure you got that joint in phase with the other end before you welded it on. I'd just hate to see this cause problems for you in the future.
  #15
Old 04-10-2007, 01:51 PM
WolfLLY's Avatar
Making Chips
Default
Yes sir. Its just like it was only welded better.
__________________
LB7 ECSB 4X4
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Front drive shaft WolfLLY Smoke Signals 27 11-04-2011 09:05 PM
LB7: should front drive shaft spin in 2wd? MuscleTruck03 Chassis & Suspension 6 06-17-2011 04:44 PM
Broke drive shaft...new one too short? jonathancasey19 Chassis & Suspension 29 06-26-2009 08:10 PM
Question: 1Pc Drive Shaft Vrabel Duramax Hard Parts 7 04-07-2009 11:01 AM
vB.Sponsors
