  #1
Old 04-13-2008, 10:39 AM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default oil cooler delete
Dan can you give me some more info on this?
after you delete the factory cooler what do you do as far as the new cooler?
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
  #2
Old 04-14-2008, 10:46 PM
Dan@PPE's Avatar
Dan@PPE Dan@PPE is offline
Diesel Enthusiast
Default
You could use a much large aftermarket cooler and reduce some restiction in the oiling system.
__________________
2500HD CC/SB LB7 2 Wheel drive 950+ RWHP
11.17@126 in the 1/4 with a 7.2x@100 in the 1/8th.
NEW BEST in the 1/8th 6.95@102, 10's Here I come!!
2500HD CC/LB LB7 4X4, Towpig
2500HD RC/LB 4X4.............. 9 seconds of fury!!!
Pushing the D to the MAX........
  #3
Old 05-04-2008, 01:21 PM
Tired Old Man's Avatar
Tired Old Man Tired Old Man is offline
Default
Quote:
Care to elate further
__________________
Sold it
New ride MBE 4000 ZF Meritor full auto
  #4
Old 05-04-2008, 06:08 PM
MAXLLY's Avatar
MAXLLY MAXLLY is offline
No Lemming Here
Default
Not to speak for Dan (this is his product), I just finished installation of this product.
1. This kit allows you to run up to #12 line from engine to cooler and back.
2. It's tapped in (2) places for feeding single or twin chargers, IIRC it has (1) each 1/2" and 1/4" ID line/holes.
3. It removes the heat load from the cooling system and isolates it a stand alone cooler.
4. It is black anodized billet alumineeum. (I like spelling it like that)
Potential issue: You'll need to fab a new portion of coolant line. The existing metal line that runs from the water pump to the back of the motor will be 5-6"" to short. The new line isn't a straight shot, you'll need a 1 3/4" "U" bend and some silicone hose to get from factory line to the new transition plate mounted to the rear cover.
If you have time and equipment/talent you could fab an entirely new hardline and flatten it to fit between the motor mount and the exhaust mani. A silicone hose will not fit and IS NOT desirable as it rests directly against the manifold. I looked into a braided line with teflon and it's only good to 450*, no line i found fit the design criteria. I base this on 750* intermitent and 230* coolant temp.
Hope this helps.
__________________
LLY/CCSB 4X4 SOCAL DIESEL-MIKE L-PPE-DPR-3 STG NX-II-ENGINEERED DIESEL-EATON-MAC RACING-BAYER 4 LINK-PW PERFORMANCE-ALSTON CHASSISWORKS-BOV-DUAL GATES.
Still tuned by a REDNECK TEXAN
  #5
Old 05-18-2008, 11:45 AM
Killerbee's Avatar
Killerbee Killerbee is offline
Got Honey?
Default
Has anyone run numbers on the stock cooler for pressure drop?
__________________
Michael
  #6
Old 05-18-2008, 07:42 PM
05smoker's Avatar
05smoker 05smoker is offline
I'm officially done!
Default
We're running a custom oil cooler delete and factory water pump delete on our puller.
__________________
2005 2500HD CHEVY CCSB, Blackout VVT, FPE SCIV w/ 1057, 3" lowering shackles, overloads removed, Cooper Zeon LTZs on BMF REPRs. SOLD
Thanks to Fleece, Blackout Performance, Genes Machine Shop, Tim, Bullfrog, Simon, Mark Broviak .......
Remote mount turbo, Electric Water Pump, Cheetah turbo - Member #1
  #7
Old 05-19-2008, 07:31 AM
MAXLLY's Avatar
No Lemming Here
Default
Quote:
Not that i am aware of.
Having dismantled the entire assembly i think i can say with some assurance that a better job can be done, from a performance standpoint. There was a guy on DP that created/did some research on a add exchanger for oil and set it beneath the bumper. I have the link on my home computer if you are interested i will post it for you.
__________________
  #8
Old 05-19-2008, 10:23 AM
Default
That was KillerBee, see previous post
__________________
Sold it
  #9
Old 05-19-2008, 04:35 PM
Killerbee's Avatar
Got Honey?
Default
That was funny!
I wanted to know because I never flow tested the stock cooler. I honestly think that it has value, the oil warms up faster with it.
__________________
Michael
  #10
Old 05-19-2008, 06:16 PM
MAXLLY's Avatar
No Lemming Here
Default
Quote:
Man I swear all the names run together after awhile....
I need to put faces with names to get it right.
__________________
  #11
Old 05-19-2008, 11:04 PM
Default
Meet Micheal
__________________
Sold it
  #12
Old 06-21-2008, 01:40 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Make sure whatever setup you use does not rob oil on cold starts.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #13
Old 11-21-2011, 09:53 AM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Default
An oil cooler delete and cleaner-looking water pump delete are on my winter list of changes to be made. Mike, I would be using a large external cooler with fans; is there an ideal location to place it so that it does not restrict lubrication during cold starts?
__________________
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #14
Old 11-21-2011, 12:23 PM
That's better
Default
Tim FYI there are some real nice water to air coolers if you want to get fancy
If your woried about looseing oil on cold starts just run the cooler high and intall a check valve in the supply line
I'm not running a oil cooler any more but I also don't Dd abby
__________________
07 RC/LB 2wd
05 CC/LB
  #15
Old 11-21-2011, 12:28 PM
juddski88's Avatar
Freedom Diesel
Default
my cooler is the one Killerbee used to sell, I got it second-hand and I have to say, it is really really nice quality. I guess I can try to mount it up higher in front of the radiator stack. My AC is gone. I am a little lost on the check valve though, what would that do for me?
Thanks Simon.
__________________
Thank you.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
