  #1
Old 03-30-2008, 07:34 PM
captnduramax's Avatar
captnduramax captnduramax is offline
Truck: 05 GMC
Engine: duramax
Transmission: Automatic
Default P1093 code keeps coming up
DTC P1093 Fuel Rail Pressure Low During Power Enrichment
Last week after I loaded up my 5th wheel I changed tunes from a mileage tune to my stocker tune. Made it out of the drriveway and engine lost all power and I couldnt go faster than about 23 mph. Changed tunes to 1 Simon send ahile back (I have used before) and towed about 200 miles at about 5mpg(yeahh). For some reason I can not get this code to go away now and stay away. 3 diff tunes with the same result. Changed fuel filter today and it lasted for about 4 miles and dash lit up. Any Ideas? I am currently running my McRat tune and have yet been able to limp tranny (stock tranny) like I did before. any help would be appreciated.
Anything else is needed?
Capt
__________________
05 GMC lly
stage 2 intake
full exhaust no cat
6" RCD lift
full nerf bars
35" toyo m/t on 16" rims
electric brake (digital)
5th wheel hitch (16,000lb)
  #2
Old 03-30-2008, 08:05 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Engine: TTS
Default
Do you have a stock FPRV?
  #3
Old 03-30-2008, 08:11 PM
Truck: 05 GMC
Engine: duramax
Default
Quote:
if thas a fuel rail then not its updated and its been done for about 8 months or so
Capt
__________________
05 GMC lly
stage 2 intake
full exhaust no cat
6" RCD lift
full nerf bars
  #4
Old 03-30-2008, 09:13 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Truck: 05 GMC 3500
Engine: lly & lb7
Default
Ok so you changed fuel filter and still no good
Does your fuel rail got a shim or a race valve in it?
Is it possible you got a bad tank of fuel? is the tank low on fuel?
Are the fuel lines leaking by chance?
Pm sent
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins.
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / Lenco-bruno trans /BD intercooler / Ted at MPL / turbo blankets from Levi
  #5
Old 03-30-2008, 09:17 PM
Truck: 05 GMC
Engine: duramax
Default
Pm sent
has shim. just filled up 3 or 4 days ago, when i filled up still had 8 gal no leak but i will have to dble check that
think it might need a lift pump? maybe tired lol ...I dont know
thanks
Capt
__________________
05 GMC lly
stage 2 intake
full exhaust no cat
6" RCD lift
full nerf bars
  #6
Old 03-31-2008, 09:04 AM
othrgrl's Avatar
othrgrl othrgrl is offline
Diesel Addiction Owner
Truck: 05 EC SB LT
Engine: 6.6L LLY Duramax
Default
Once you throw a 1093 it gets easier and easier to do it it seems. I went straight to the PPE race valve and just put on a AirDog 150gph lift pump but am waiting to get my front end with elocker back so I can drive it.
__________________
Dustin
05 Chevy ECSB SS, DA EFI Live, Custom DA Trans, Single CP3, Single turbo, Fuel only
835hp 1350tq - 04/18/13-------------11.18 @ 122 - 08-07-09
DIESEL POWER CHALLENGE 2010 - 3rd Place
Coasted to a 10.74 before retirement to street truck status.
  #7
Old 03-31-2008, 09:20 AM
IOWA LLY's Avatar
Yes, its really me
Engine: TTS
Default
Do a bottle test to make sure its not your FPRV.
  #8
Old 03-31-2008, 09:41 AM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Truck: 05 GMC EC/SB 2500HD
Engine: Duramax LLY
Default
Good advice. No need to shim the PRV if it's not leaking.
The P1093 is the oldest of the LLY performance problems, and we know shimming/race-valve fixes 99% of trucks with this problem.
My racing tunes won't "limp", but that does not stop the valve from dumping rail pressure.
We first saw this at ~370rwhp, and it has also affected stock tuning trucks, so everyone is a potential victim with an LLY.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #9
Old 03-31-2008, 09:56 AM
othrgrl's Avatar
Truck: 05 EC SB LT
Default
You can also change the 1093 to not cause a limp mode through EFI Live, you will still be able to pull the code when it happens but it won't cut fuelling. Race valve and lift pump should have you fixed though - and ready for more when you are.
__________________
Dustin
  #10
Old 03-31-2008, 05:05 PM
dmaxtruck dmaxtruck is offline
Perfect Sleeper
Default
I had the 1093 as soon as I got my injectors, I threw a shim kit on and that solved it except for at very high speed WOTs. Threw the FASS 150 on it and haven't had it since.
  #11
Old 03-31-2008, 06:41 PM
Truck: 05 GMC
Engine: duramax
Default
Quote:
I think a lift pump is next to keep it consistant. I am hope there is no leak in the system, should know tomorrow if there is. (getting all the bushings in the front end replaced and he is pressure testing it for me).
thanks everyone for the input
Capt
__________________
05 GMC lly
stage 2 intake
full exhaust no cat
6" RCD lift
full nerf bars
  #12
Old 03-31-2008, 07:48 PM
othrgrl's Avatar
Truck: 05 EC SB LT
Default
Do a search for the bottle test - it is the best way to pressure test it. If you are talking about pressure testing the fuel rails I kinda doubt that whoever is pressure testing it has anything that will put anywhere close to 23,000 psi in it. The PPE race valve is cheap and a quick fix. If you are talking about the rest of the system (tank to pump) leaking than it makes more sense but if you don't smell raw diesel or see any drips while it's running you are probably fine.
__________________
Dustin
  #13
Old 03-31-2008, 08:10 PM
Truck: 05 GMC
Engine: duramax
Default
Quote:
I have the race valve in... no drips at idle (that i have seen but will double check) not sure how he is testing it but will find out tomorrrow. Thanks for all the help...everyone. lift pump maybe next week and go from there.
Capt
__________________
05 GMC lly
stage 2 intake
full exhaust no cat
6" RCD lift
full nerf bars
  #14
Old 09-15-2011, 12:36 AM
onebadduramax's Avatar
onebadduramax onebadduramax is offline
One Bad Duramax
Default
so what did you do to fix the issue ?
__________________
Just One Bad Duramax
http://www.8-lug.com/features/chevy/...cab/index.html
Current Sponsors: Ultimate Truck Gear,Hayden Automotive,Duramax Tuner,S&B filters,Going Greener Today,All ways Welding,Optima Batteries,Interco Tire Corporation,Mag-Hytec,818 Autosport,Herculiner,Setrab,Silverline,Titan Fuel Tanks,AirDog,Dee Zee,Power Stop,VIAIRCORP, MisterDecal.com Mean-Green.com Yukon Gears, ISSPRO MileMarker,Socal Diesel
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
