  #1
Old 03-07-2008, 12:16 PM
LB7Diesel's Avatar
LB7Diesel LB7Diesel is offline
Oh Boy!
Default 2-1 hard downshift
My trans has had a hard 2-1 downshift for awile now. It only does it once in the morning when cold. It won't do it anymore until the next mornings first 2-1 downshift. Any thoughts?
__________________
2004 GMC 4x4 CC,SB LB7
And a little of This and That.
12.7 @ 105mph.
11.7 @ 115mph. N2O
O.S.(15189044)
" WHO IS MR.GOODWRENCH "
FORD= " Forget Out Running Duramax's"
FLORIDA DIESEL TRUCK CLUB MEMBER #13
TEAM BORROWED TIME MEMBER #13
  #2
Old 03-07-2008, 12:25 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
There is a set of taps that is just for downshifting. When I would run a Kodiak TCM it would knock your teeth out at first.
We need to figure out what to adjust.
Make sure your TCM tune DOES NOT have adaptive downshifting DISABLED.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #3
Old 03-07-2008, 12:26 PM
Bluemax's Avatar
Bluemax Bluemax is offline
Default
Mine does it too. I hope it's a normal thing.
__________________
kickin440@yahoo.com
  #4
Old 03-07-2008, 12:27 PM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
Quote:
Normal in some Alli's.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #5
Old 03-07-2008, 12:42 PM
MACKIN's Avatar
MACKIN MACKIN is offline
Smell My Finger...
Default
Weird it goes away after you get some heat into the tranny. Is it when you apply the brakes? I ask becomes sometimes mine has some quirky downshifts when braking.
But I'll get a buzzing in the peddle like the ABS is kicking in.
  #6
Old 03-07-2008, 12:56 PM
Bluemax's Avatar
Default
Mine does it whether on the brakes or not. I've never had the abs feeling like that though.
__________________
kickin440@yahoo.com
  #7
Old 03-07-2008, 01:14 PM
Mike L.'s Avatar
Default
My truck does it also. I would imagine that it has something to do with the apply and release of the larger clutch stacks, different friction coefficient, and thicker fluid when cold. I think the changes that have been made in a built Alli falls out of the adapt strategy parameter.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #8
Old 03-07-2008, 01:55 PM
LB7Diesel's Avatar
Oh Boy!
Default
Great feedback and info guy's, Thanks
As long as Kevin and Mike's truck do it, I'm ok with it
I'm not so sure it's heat that keeps it from continuing to do this.B/c I can go 100ft stop and it'll downshift hard, go another 100ft and it won't do it anymore Maybe it's from sitting all night and things sticking a little.
__________________
12.7 @ 105mph.
11.7 @ 115mph. N2O
O.S.(15189044)
  #9
Old 03-07-2008, 03:40 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
Wendy also does it once in a while.
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #10
Old 03-09-2008, 11:09 PM
Philtopgun's Avatar
Philtopgun Philtopgun is offline
Nice n Easy
Default
Crazy, very cold here the other night about 29 degrees and mine did it from 2 down to 1. It has never done that before... I warmed the truck up and got up to second gear before the first stop sign. I slowed down and it hit 1st hard. Has not done it since....
__________________
PHIL
2005 GMC 3/4 CC 4x4 SB LLY
Mcrat efi, Banks Ram Air & 4" exhaust, GMax5, MBRP 4" front pipe-cat delete, ADII 165, 3 colbalts n pillar, Shim Mod, SD sleeves, Tony Burkhart steering stabilizer, SD boost manifold, Mike L. Pump Rub Kit, 275/70 bfgs at on stockers now.
1/4= 13.0/104
(Special thanks to Mcrat family, Mike L., 2500HD-Dan-o, Larry Jewell, Alligator Performance, Josh H
still on shelf: passenger race valve,egr blkr
99 gmc 1/2 rc sb 6.0(LQ9),4l80e,efi live
We need a Texas club...
  #11
Old 03-10-2008, 08:09 AM
Cobra#3747 Cobra#3747 is offline
Default
I get it with Tow Haul more than anything, even warm.
  #12
Old 03-15-2008, 09:20 AM
LBZ4Me LBZ4Me is offline
FNG
Default
Mine was doing the same thing, and seemed to do it mostly while in Tow/Haul mode while braking hard. Like an ass it was one of the things I complained about to the dealer when my warrantee was about to expire, thinking I wanted to get it on record that there were tranny issues, in case it blew up for some reason :-). Well after I picked it up they told me there was a reflash for the computer. (didn't say if it was a trans or engine flash). I was pissed, I really didn't want them messing with my tune (was back to stock at the time) but was nothing I could do at that point. Now that I'm done bitchin the trans has never hard downshifted since, and it was doing it daily when I took it in. Maybe those knuckleheads actually have a fix????
  #13
Old 03-23-2009, 09:03 AM
stroke250's Avatar
stroke250 stroke250 is offline
I May Be Lost...
Default
mine does this also. seems to do it when cold and you can feel the abs kick in too. doesn't seem to do it with tow haul on. upshifts and downshifts fine otherwise.
__________________
Ventured away from the diesel world currently... trying some gasser trash
  #14
Old 03-23-2009, 09:51 AM
Cougar281's Avatar
Cougar281 Cougar281 is offline
Default
Mine was doing this until I broke it; since I rebuilt it, I haven't had that funky 2-1. Mine did all the stuff described above; goes away when warmed up a little, ABS kicks in...
__________________
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
  #15
Old 03-23-2009, 10:20 AM
stroke250's Avatar
I May Be Lost...
Default
from what mike l said(please correct me if i am wrong mike), it seems some just do it and others don't.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
