  #1
Old 05-21-2011, 07:24 PM
1chevy02's Avatar
1chevy02 1chevy02 is offline
Default LB7=LMM Swap
I have been looking for a good lbz with trans and electronics to swap into an 04 lb7. I found a good deal on a wrecked lmm, and was just curious how much different the lmm is and if it would be possible to swap it in.
__________________
02 Chevy loaded LT package
4x4 ccsb
Efi live
305/65/17 Procomp Extreme AT on dodge wheels lbz cp3 dsp5
Suncoast Gmax 5 and Precision Converter installed by me! Thanks George at Suncoast!
high idle, Stewart Warner guages, PPE boost increasing valve, full Cognito kit, various other mods, ported and polished turbo intake elbow
FASS 150, MBRP downpipe, Diamond Eye Exhaust.
  #2
Old 05-22-2011, 01:54 AM
chrisuns's Avatar
chrisuns chrisuns is offline
Default
Have to swap to the LBZ injectors, ECM & TCM, the egr intake to get rid of the butterfly valve, reprogram the GPCM, MAYBE a LBZ engine harness (I'm un-sure of that, as I don't have a LMM wiring diagram on me atm.). Off the top of my head that's about it, but I haven't done much research into it. -- Just to give you a general idea.
__________________
2007 LBZ - Few go fast and handling parts.
  #3
Old 05-22-2011, 05:17 AM
greygoose08's Avatar
greygoose08 greygoose08 is offline
Gearhead
Default
he knows what he talking about!!! ^^^ he helped me through mine
__________________
2009 GMC SIERRA 2500HD SLT CCSB - EFI Live by Bobo, Big Dipper Built Trans, EGR Blocker Plate, PCV Reroute, Isspro triple guage, MBRP 5" Exhaust, Banks Intake, 285/70/17 BFG's, Raptor 5" Oval Wheel to Wheel Steps, 15% Tint Front's, 5% Rears, Weatherguard Toolbox, Recon Smoked Cab Lights, LML HD Grille
  #4
Old 05-22-2011, 05:41 AM
RichLMM's Avatar
RichLMM RichLMM is offline
Default
skip the swap hassle and give it to me to put in my 6.0 gasser..
__________________
2001 2.6 truck the other woman
2013-2014 shootout productions 2.6 points champ
thanks to caleb baker@blackout performance
  #5
Old 05-22-2011, 08:11 PM
1chevy02's Avatar
Default
Ok thanks guys. So in other words if it is cheap enough it would be worth the hassel
__________________
4x4 ccsb
Efi live
  #6
Old 05-22-2011, 08:16 PM
chrisuns's Avatar
Default
Yep, all depends what your time is worth in dollar value to you. Be prepared to be out of the money for a bit though. You're going to as least eat the injectors and computers for a few weeks. Not sure on the demand of stock LMM injectors but it could be awhile before you sale them.
__________________
  #7
Old 05-22-2011, 08:23 PM
JoshH's Avatar
JoshH JoshH is offline
Default
I wouldn't worry about converting the LMM to an LBZ; just bolt it in as is. Put in a DPF delete tune and call it done.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #8
Old 05-22-2011, 09:53 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
x2, since it is going into an '02, the electrics won't plug-n-play in either case, might as well save some trouble and keep it an LMM.
__________________
  #9
Old 05-22-2011, 11:38 PM
chrisuns's Avatar
Default
Quote:
Yes, that would clearly be the case if he was putting it in a 02. However, he earlier stated it's going into a 04. Offering poor advice because you didn't read his question, isn't going to help anything but make it more difficult for those who know what the hell is going to to explain it.
__________________
  #10
Old 05-22-2011, 11:48 PM
chrisuns's Avatar
Default
Quote:
Not that simple. For starters LMM and LBZ communication protocols are different. LMM ECM actually talks to the truck though high speed. Where as the LBZ ECM & TCM is programmed by high speed and talk to each other in it, but they talk to the rest of the truck low speed. Same reason it's really complicated to put a LLY or LBZ in a 02 and older vehicle. In this case however, the engines (LBZ and LMM) are almost mechanically identical for the most part and can be converted to one another. Now if a LMM TCM and ECM can be programmed to be back to the older O.S. I belief so. However, I don't think it is as simple as EFI live to do this. Last I knew it took bench programming, which is a lot more than the average home user has.
__________________
  #11
Old 05-23-2011, 06:28 AM
Drholliday's Avatar
Drholliday Drholliday is offline
Default
Can you explain why he has to convert it to an LBZ to make it work? Is it just so the computers acan talk to the other computers in the truck?
The injectors shouldn't need to be swapped out BTW. LBZ and LMM injectors are interchangeable. Meaning an LBZ can run on LMM injectors and vice versa.
__________________
Chris
2006 Chevy 2500HD LBZ/Allison ECSB 4x4 Greystone metallic
Tuning and Transmission by Diesel Addiction. A special thanks to Dustin for all the help.
BatMo S475, 3" boost tubes from turbo to engine, custom 5" intake, custom Y-bridge, LLY 2x CP3's w/LBZ kit and pumps, ported LLY fuel rails.
12.18 @ 112
12.42 @ 106.3 (stock injectors, CP3, and turbo, no drugs!)
531 RWHP / 940 RWTQ 10/11/08 on Wayne's Dyno in Jville NC
USMC 2002-2010
  #12
Old 05-23-2011, 07:01 AM
DAVe3283's Avatar
Default
Quote:
My bad, he did say an 04. I somehow missed that in his post, and saw an 02 in his signature. No need to get snippy though...
chrisuns is actually right when he says it is how the computers "talk" to the truck. The protocols that the LMM uses to talk to the rest of the truck are different than what the 04-06 trucks use, so if you put the LMM in the older truck it won't be able to communicate. If the computers don't talk to the rest of the truck, thinks like the security system won't work right, and presumably the OP wants the truck to work like factory.
__________________
  #13
Old 05-23-2011, 08:51 AM
chrisuns's Avatar
Default
Can you explain why he has to convert it to an LBZ to make it work? Is it just so the computers can talk to the other computers in the truck?
The same reason I mentioned above. -- Those O.S. speak two different languages. Can't leave an open loop in the system either otherwise it will throw codes. The injectors have to be swapped, they're flow matched then programmed into the ECM and GPCM. -- LBZ 6 hole IIRC and LMM are 7 hole, it'll screw the whole injection chart if you interchange these. They know how many holes each injectors has, flow charts ect ect...
__________________
  #14
Old 05-23-2011, 09:14 AM
Drholliday's Avatar
Default
With some one who already has EFI live the injection tables in the tunes probably won't be staying stock for long. I'm just saying they will work with an LBZ ECM. Its backwards too, LMM's have one less whole then the LBZ. It really doesn't matter if on flows a touch more then the other (between LMM and LBZ)... If it would matter guys who put bigger injectors in their trucks would be screwed.
__________________
Chris
12.18 @ 112
USMC 2002-2010
  #15
Old 09-23-2014, 02:04 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
Bumping this up....
Im doing a standalone harness for a customer, and he has an LMM engine. Its 100x easier to do standalone with 2001-2007 ECM OS's because cruise control and speedo/tach are configured as discrete signals on the older trucks, as opposed to just being sent as data messages over GMLAN on 2007.5+ trucks.
So Im suggesting the guy buy an LBZ ECM, plug it into his LMM harness (there are a couple minor pin differences, Ill worry about that when I build the harness), and run the LMM as an LBZ.
Its been years (probably 7 years) since I messed around with LBZ/LMM "hybrid" tunes. IIRC the pulsewidth and timing tables were a little different but thats about it. So if I just use LMM pulsewidth/timing tables as a start, copy-pasta them into the LBZ tune.....is there any reason an LBZ ECM wont happily run an LMM (injectors)??
Ill probably just disable the "injector flow values not programmed" codes, because Im not sure if the LBZ ECM/GPCM would properly learn LMM injector values... I doubt thats going to cause a huge issue??
thanks
Ben
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
