  #1
Old 05-11-2011, 04:59 PM
Dmaxbandit's Avatar
Dmaxbandit Dmaxbandit is offline
WHAT!!!
Default Thermostat
Was wondering if I took out my thermostats for the summer time, how would the engine act to it? It's been running 200 deg plus & the weather is just starting to get hot. Any ideas?
__________________
05' Silverado 2500HD 4X4 cc/sb
4" catback exhaust, K&N cold air
Moto Metal 16" 951's
Nerf Bars I made (N-Fab look alike)
Superchips program & gauge
  #2
Old 05-11-2011, 08:27 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
Normal operating temp is about 210 on the dash gauge. When you see less, the thermostats even aren't open yet. If you start seeing over 225, then you might issues. I have lower temp thermostats that are intended for racing, but they won't fix overheating, and might lower your fuel economy. The engine will protect itself from actual overheating, which is about 250 deg.
Diesels actually like it hot. It gives you a more complete burn.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #3
Old 05-11-2011, 09:45 PM
TeaBagger2006's Avatar
TeaBagger2006 TeaBagger2006 is offline
Im a Garrett Nut Swinger
Default
So you're saying my p0128 is hurting my fuel economy??? My truck won't go over 168
I better replace my darn thermostats then
sorry for the highjack
__________________
Joe
Loosest Tailgater in USA
2006 GMC 3500 D/A LBZ SRW CC/LB SLT 4x4
8" Fabtech lift 37x13.5/20 tires....Mike L trans....some go fast goodies
13.20@106mph
'06 Jetta TDI
  #4
Old 05-12-2011, 06:43 AM
McRat's Avatar
Diesel Hotrodder
Default
Both gas engines and diesel engines get their best mileage when hot. It's a thermodynamic thingy. If you are using fuel to heat water, then disposing of that heat into the atmosphere, it does you no good. Plus when fuel droplets hit the metal surfaces, the cooler the metal is, the longer it takes to vaporize that fuel. Only fuel vapor is flammable, not liquid.
__________________
Pat and Kat McSwain
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
