  #1
Old 04-27-2011, 06:58 AM
duramax-rob duramax-rob is offline
duramax-rob
Default How to adjust NSBU switch?
I would appreciate any help. I replaced nsbu switch with OEM and since then I have to push the gear shift lever a little harder into park to be able to turn the ignition switch to get the key out. About half the time the lever will go far enough to turn the key, the other times I have to push the gear shift lever again and then I can turn the key to take it out. The park light mostly just flashes once and them stays off most of the time when in park.
It seams to me that the nsbu switch needs to be rotated to make it go all the way in park so that the light will stay on and I can also remove the key. What is the direction to rotate the switch when looking at the switch from the passangers side of the truck and does that sound like the fix or do I have to pull the switch, set the alignment clip back in it and reinstall the switch again. Except for the not going all the way back into park, it works great.
Any help would be appreciated.
Thanks, Rob Brockmeyer
__________________
01 duramax CC Dually 4X4 Red, boost and pyro Guages PPE Standard Gooseneck Hitch Allis Chalmers 816 Backhoe kubota b3200 w/loader and backhoe
  #2
Old 04-29-2011, 09:15 AM
duramax-rob
Default
I would appreciate any help with how to adjust the NSBU switch.
Thanks Rob
__________________
  #3
Old 04-29-2011, 10:12 AM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
NSBU switch should not stop lever from going into park. I would start by adjusting the cable first.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #4
Old 04-29-2011, 01:12 PM
duramax-rob
Default
thanks mike, i'll do that first!!!!!1
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
