  #1
Old 04-12-2011, 10:32 AM
ocwelder's Avatar
ocwelder ocwelder is offline
Truck: Blk 02 CC/SB 4X4
Engine: LB7
Transmission: Automatic
Default 2-Stroke Oil as a fuel additive???
Had an ol' timer stop in today and as always we ran the gamut of conversations, so at one point he tells me he's been running 2 stroke oil as a fuel additive in his 24v. So I'm like ok? for how long? he said since he brought the truck and it has about 225 on the clock with the same vp44 and lift pump. Sooooo with the uls fuel we have today it doesn't “sound” like a bad idea. ANY OPINIONS on this. Oh and the fuel he used to make for tractor pulling is..... well…… way out there......<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
5 gal diesel<o></o>
1 qt straight 30wt<o></o>
1/2 qt gas (didn't specify octane) <o></o>
__________________
2002 Silverado LB7 CC/SB 4X4
Mods: Stuff to go faster!
  #2
Old 04-12-2011, 10:40 AM
MACKIN's Avatar
MACKIN MACKIN is offline
Smell My Finger...
Truck: LESS AT THE MOMENT
Engine: Combustion
Transmission: Hybrid
Default
I've heard of other people using 2-stroke oil as a additive.Some swear by it also!
Would I? No as with the cost of these Bosch Injectors and system I'll stick with a non-alcohol base fuel additive.
To each their own.
__________________
I have nothing want nothing because what I have cost me to much to have.
01 Big Dually (Gone but not forgotten)
05 Fat-Boy (gets it done)
83 CJ7 (slug but cool)
07 Audi A4 ( I like German Girls they're HOT!!)
LIFES JOURNEY IS NOT TO ARRIVE IN HEAVEN SAFELY IN A WELL PRESERVED BODY,
BUT RATHER TO SKID IN SIDEWAYS,
TOTALLY WORN OUT, SHOUTING,HOLY SHIT WHAT A RIDE!
  #3
Old 04-12-2011, 10:51 AM
ocwelder's Avatar
Engine: LB7
Default
I hear ya on that one... but i was also the kid the stuck the screw driver in the wall socket just to see what would happen!
__________________
  #4
Old 04-12-2011, 12:00 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Truck: 95 SUBURBAN
Engine: LB7
Default
Ashless 2 stroke oil is one of the reccomended lubricity additrives to combat ULSD that we now get at the pumps. Back when teh ydid the lubricity tests they found that plain old 2 stroke when mixed at 200:1 was 2nd only to bio-diesel at 2% for lubricity and protection levels to combat wear from ULSD. Just make sure it is a decent quality ashless 2 stroke oil and it is good for your fuel system(not good if you have a DPF or cat though as it can increase particulate output).
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, 3.42 gears, 261 T-case
Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4 and a PI ML converter
DIAMONDEYE 4" exhaust with a CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump and pump rub kit.
  #5
Texas Chevy's Avatar
Texas Chevy Texas Chevy is offline
Truck: CC/LB
Engine: LML
Default
In the Cat engines we had in our trucks in Iraq the injectors kept going out so the mechanics had us putting transmission fluid in the fuel which some how worked and stopped te injector problems we were having
__________________
07 silverado classic. CCLB sold
2011 LML 2500hd CC/LB LTZ. H&S xrt pro. auto meter boost and pyro guage. Big thanks to Jake@Diesel Mafia
  #6
Old 04-12-2011, 12:23 PM
Mike_S's Avatar
Mike_S Mike_S is offline
OOPS!
Truck: CC/SB
Engine: LB7
Default
While older mechanical injection systems seemed to like ATF, these comon rail systems have much tighter clearances and dont handle ATF well. They do however love 2stroke oil. I use a cheap TCW3 rated oil, at a quart to a tank (24 galons) and i have had good luck. Seems to keep balance rates in check, and some people say it seems to make the truck quieter and smoother, but i think that is all subjective. In any case, i run Howes addative in half the recomended amount and 2stroke oil, seems to work well for me.
__________________
Nancy:
2004 CC SB, LB7, 2500 HD, Borg Warner spinny thingy, Carillo tough stuff, Transgo/suncoast tranny stuff, DMP squirt guns, and a couple custom parts.
The General:
1994 EXT Cab, SB, 1500 HD, 350 SBC, Whole Buncha $hit And Its Still Not Fast.
(I do all my own work...and thats not always good)
Good, Fast, Cheap...You Can Only Have Two!
You only need 2 tools: duct tape and WD-40. Duct tape for when it moves and isnt supposed to, and WD-40 for when it don't move and should!
  #7
Old 04-12-2011, 12:34 PM
D-MAX Mafia's Avatar
D-MAX Mafia D-MAX Mafia is offline
Hood down, smoke up!
Truck: CC/SB
Engine: LBZ
Default
Quote:
I have been running Costal Type F ATF in my truck for the last 50,000 miles. Fill the fuel filter with it at changes and between 2-4 quarts at fill up. Before ATF I used Lucas. Costal is the cheapest I could find besides the Love Station Brand. Balance rates are good and the truck runs better with it than without. Truck has 137,000 with no issues, I will continue to use it.
__________________
Ben
2006 CCSB LBZ 4x4
12.6@105
160,000 miles
For Sale
2011 CCSB LML Z71 traded for a 2013 Mazdaspeed3
  #8
Old 04-12-2011, 12:42 PM
ocwelder's Avatar
Engine: LB7
Default
well I'm goona have to give it a try then. I had hear of using 2-stroke oil before but never asked.
__________________
  #9
Old 04-12-2011, 12:49 PM
Righteyeblind's Avatar
Righteyeblind Righteyeblind is offline
Truck: CCSB
Engine: LB7
Default
I run Super Tech 2 stroke oil from Wal-Mart. Seems to work well. 16oz per fill up. I was reading that ATF has a high ash content so I went away from that.
__________________
"Pepper" 02 CCSB
Tuned by Tony
Carillos, stock LB7 pistons, head/main studs, Socal springs
GMAX 5 with 1055 converter
Garrett TV8403(GT55/47 hybrid)/ITS 74mm BB compounds
FASS 260 pump
ATS Dual Fuelers
Kennedy Diesel 40 over sticks
THANKS to Albert (BurnDown)<<<BIG HELP!!
  #10
Old 04-12-2011, 03:52 PM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Truck: 2002 Chevy 2500HD
Engine: LB7 BABY!!!!!!
Default
Good ol Wally world 2-stroke here. 16-20oz per fill up. Smooths it out & quietens it too IMO.
__________________
Mitch
02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, 5% tint, partially debadged , Rhino Bed Liner, Cheap Junk Air Intake, SuperDiesel Intake Manifold and Ported Turbo Inlet, 16x8 Eagle 194s w/ 265s
1983 GMC K30 CC SHORT BED
4wd pulling truck awaiting LBZ Dmax/ZF6 conversion...
  #11
Old 04-12-2011, 04:14 PM
TNRGreene TNRGreene is offline
Kicked to the Curb
Default
I use Distance plus, 1oz for 25 gallons
__________________
I don't carry a gun to look for or start a fight. I carry one to finish a fight I never wanted to be in.
  #12
Old 04-12-2011, 04:24 PM
SmokeShow's Avatar
Default
1 oz for 25 gal?!?! LOL that must be some potent stuff!!
__________________
Mitch
  #13
Old 04-12-2011, 04:27 PM
Kicked to the Curb
Default
Quote:
No typo on my part either
__________________
  #14
Old 04-12-2011, 05:24 PM
ecc_33's Avatar
ecc_33 ecc_33 is offline
Junior Member
Truck: 2002 Chevy ECLB dmax
Engine: Duramax 6.6 lb7
Default
i have been running ATF for about 4 years now. I put anywhere from a quart to a couple gallons in lol....Im not bashful about it. I have put as much as 2 gallons of ATF and 1 gallon of hyd fluid in at once just to get rid of it. Hasn't hurt anything yet
__________________
02 extra cab long bed
Thanks: CRANK IT UP DIESEL PPE ATS SUPER DIESEL MCRAT RACING
CREATURES OF THE NIGHT BES RACING
Carrillo rods, Hamilton valve springs, ATI damper, 60% bigger nozzles, head studs, S475 turbo, 4inch lift kit, ATS dual fueler, ATS Tranny,Bunch of SD parts,lobonte water meth, NOS,6inch stack, AD 165gph,
best time 11.63 at 116 49,200 miles
  #15
Old 04-12-2011, 05:31 PM
ocwelder's Avatar
Engine: LB7
Default
Thats crazy! 2 gallons of atf and a gal of hyd!!! in one shot.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
