  #1
Old 10-16-2010, 04:02 PM
xcablb7's Avatar
xcablb7 xcablb7 is offline
Default Fuel leak
anyone ever have a ppe fuel rail inlet fitting leak ? The one that goes in place of the plug on the drivers rail . I tightend it pretty good and it still leaks when i rev the truck up.
__________________
04 LB7 Denali conversion
626 h.p 1142 tq 5-8-2010 a5k, stock cp3
gt 4088r, gt4718 twins,
custom cam, 15.5:1 forged mahle w/ reliefs
ppe dual fuelers w/ lbz pumps 80% extrude hone inj
837 h.p. 1380 tq 5-14-11
11.40 @ 125.5
Thanks to Toman tysmith and Justind
  #2
Old 10-16-2010, 04:38 PM
cmitchell17@comcast.net cmitchell17@comcast.net is offline
cmitchell17
Default
Are you talking about the FPVR or something else? Ive been having trouble with my LLY FPVR leaking internally and I found a ppe rail for cheap so I decided to just get a whole new ppe rail.
  #3
Old 10-16-2010, 11:41 PM
JoshH's Avatar
JoshH JoshH is offline
Default
What are you talking about exactly? I know a guy who has a PPE dual CP3 kit on his LBZ, and the fitting for the second CP3 goes into the back of the driver's side rail where the FPRV is normally installed. Is that what you are talking about? If so, yes. His was loose, and it leaked.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #4
Old 10-17-2010, 02:37 AM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Default
Quote:
Did you leave the puck that was behind the plug out. If so thats your trouble you should of drilled it out to match the fitting that you got with the kit installed it then the fitting.
3. Remove plug from end of fuel rail with a TB50 Torx wrench or socket and install #7, Fuel Rail Fitting.
I
mportant: Early Model LB7 trucks may have a block off plate behind torx plug fitting, if so Remove this block off plate and drill out to same size as supplied fuel rail adapter fitting.
http://www.pacificp.com/pdf/Dual_Fueler_LB7_01-04.pdf
__________________
Name to come
2013 GMC Denali HD 2500 ccsb,100%stock,spray liner,B&W
Sold but not forgotten
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
11.53 @ 116.92 1.66 60's
  #5
ripmf666's Avatar
Default
Quote:
It feeds from the front of the rail on the LB7's Josh.
__________________
Name to come
  #6
Old 10-17-2010, 06:05 AM
xcablb7's Avatar
Default
thanks henry i spaced out checking that because my truck is an early 04, but my spare motor that i used the rails from is an 01 i'll have to check that today
__________________
11.40 @ 125.5
  #7
Old 10-17-2010, 07:52 AM
xcablb7's Avatar
Default
that was it damb little plug was in there, why do 01's have to be difficult ? lol
__________________
11.40 @ 125.5
  #8
Old 10-17-2010, 08:08 AM
dmaxfireman's Avatar
dmaxfireman dmaxfireman is offline
'Can do' kind of guy
Default
make sure the high pressure leak did not damage the threads
__________________
-Fireman
  #9
Old 10-17-2010, 09:58 AM
xcablb7's Avatar
Default
seems to be ok thx,i'll keep an eye on it
__________________
11.40 @ 125.5
  #10
Old 10-17-2010, 02:25 PM
ripmf666's Avatar
Default
Did you drill it out to match and then replace it with the fitting?
__________________
Name to come
  #11
Old 10-17-2010, 02:41 PM
xcablb7's Avatar
Default
yeah just like the instructions said, thx
__________________
11.40 @ 125.5
  #12
Old 10-17-2010, 08:48 PM
ripmf666's Avatar
Default
Your welcome
__________________
Name to come
  #13
Old 10-18-2010, 12:12 PM
xcablb7's Avatar
Default
It's all set no leaks thx guys
__________________
11.40 @ 125.5
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
