  #1
Old 05-06-2010, 01:26 PM
03dmaxin's Avatar
03dmaxin 03dmaxin is offline
It aint pollut. its POWER
Engine: LB7 baby
Transmission: Automatic
Default read motor plate
does anybody have a diagram of everything you pull off to beable to mount up my engine to a stand to flip it and pul the oil pan so any advice helps thanks guys
__________________
03 gmc 2500 hd 4x4 duramax lb7
Stack, programmer,mod waste gate, banks innercooler,
custom intake, boostgauage, next projects-hood stack,
convertor locker/unlocker, and after the build then a set of.....
twins
(Build in progress)
  #2
Old 05-06-2010, 02:13 PM
hondarider552's Avatar
hondarider552 hondarider552 is online now
On jackstands again
Truck: CC/SB
Engine: Isuzu 6.6 LB7
Default
Remove the rear aluminum cover.
__________________
2003 Chevy RC/LB. S475, Mike L trans w/1058, Airdog2, EFILive. Caltracs. Crank It Up centerlink/sleeves. 5" intake from Dmax711, Rancho's, ATS, Merchant and PPE parts, Carrillo's, ARP head, main, rocker & injector studs, Hamilton springs, LB7 cut pistons, DDP 38LPM sticks, LBZ CP3. Lowered on 22's
RIP stock engine 03-16-13
2006 Chevy Colorado I5. Not stock.
Tailgate Crew Member #3
  #3
Old 05-06-2010, 02:56 PM
03dmaxin's Avatar
Engine: LB7 baby
Default
yea what all do i have to take off i already have the heads and turbo off so its basically a short block and i unbolted a bunch of boats but its actin like i have a bolt somewhere thats not undone..do i have to unbolt any of the oil pan bolts or no?
thanks for the advise
__________________
twins
(Build in progress)
  #4
Old 05-06-2010, 04:30 PM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Truck: 2006 2500 HD ex cab
Engine: Duramax 6.6
Default
Yes you have to remove the bottom black oil pan and remove the bolts that hold the rear adapter from the inside. There is a spor called Gm specs here that shows everything that you need.
__________________
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live,MPI twins intalled by BigDipper,PPE dual cp3,PPE lift pump,BigDipper 30% injectors, BigDipper Trans Precision ML converter.
Alot Of thanks To George aka BigDipper
11.53 @ 116.92 1.66 60's
RIP LBZ 6/1/08@5:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
  #5
Old 05-06-2010, 04:32 PM
Jarasic's Avatar
Jarasic Jarasic is offline
Diesel Enthusiast
Truck: CC/SB
Engine: LB7
Default Adapter Plate Removal
There are at least three hex head upper oil pan bolts that need to be removed to remove the rear adapter plate and two small 12mm head bolts that bolt to the oil cooler (on oil filter). Just pulled one apart. Let me know if you need anything else.
ripmf666 beat me to it.
  #6
Old 05-06-2010, 04:38 PM
03dmaxin's Avatar
Engine: LB7 baby
Default
ok ima go remove the black oil pan and let u know how turns out after that i appreciate it big time guys
__________________
twins
(Build in progress)
  #7
Old 05-06-2010, 04:40 PM
03dmaxin's Avatar
Engine: LB7 baby
Default
jarasic if u dont mind can u give me a call on my cell to let me know what else i need to do so i dont have to keep walkin in and out to get on the comp.
thanks
dallas
1-337-368-1750
__________________
twins
(Build in progress)
  #8
Old 12-17-2011, 11:12 AM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Truck: EC/SB
Engine: LBZ
Default
So you need to remove the flexplate, and bottom oil pan to be able to use an engine stand?
__________________
Ben
12.26@108.8
7.78@87.7
Stock Turbo Puller
Quote:
Originally Posted by Utahski View Post
The absolute most obnoxious bumper sticker is one that's been around for awhile.....Obama-Biden '08
Quote:
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #9
Old 12-17-2011, 12:53 PM
TheBac's Avatar
TheBac TheBac is online now
Truck: 2003 GMC CC/SB
Engine: LB7-Z
Default
Quote:
No, you just need longer bolts (110mm long IIRC). Use the two upper holes on either side of the top trans bolt hole and the two lowest holes in the honeycomb area of the rear cover that run into the block.
__________________
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
-- Retired
"The Flying Brick" 1999 Silverado 1500 2wd RC/SB LB7 Duramax/5spd Allison -- hope to get started building in Spring '13
2014 can't get here fast enough, 'cause 2013 sucks....
Two wrongs dont make a right, but three rights do make a left.
Reality is just a matter of perspective.
I know just enough to be dangerous.
  #10
Old 12-17-2011, 01:18 PM
<<<< No Horsepower
Truck: EC/SB
Engine: LBZ
Default
It said in a GM service guide not to run bolts throught the adapter plate. If you or anyone else has done this without issue I don't see it being a problem, it would make life easier.
http://www.duramaxdiesels.com/forum/...mounting+stand
__________________
Ben
12.26@108.8
7.78@87.7
Stock Turbo Puller
  #11
Old 12-17-2011, 01:21 PM
TheBac's Avatar
Engine: LB7-Z
Default
IMO, for temporary, theres nothing wrong with it. Could be they worry about the weight of the engine starting to deform the aluminum into the stand mounts after a period of time.
Do what you feel is correct.
__________________
Tom
12.14@111.15
-- Retired
  #12
Old 12-17-2011, 01:48 PM
ripmf666's Avatar
Engine: Duramax 6.6
Default
Tom if he wants to remove the crank the rear adapter has to come off before the stand. But heck we always rear down while still on the ground then hanging in the air. The reason gm does not want you to bolt to engine stand is most would use the trans bolt holes. And there more of a insert and will pull out or strip easy.
__________________
She's Alive again
  #13
Old 12-17-2011, 02:35 PM
<<<< No Horsepower
Truck: EC/SB
Engine: LBZ
Default
But using longer bolts it would go thru the plate and screw into the block? I'm I understanding that correctly? If you use the short trans bolts only that is when the potential problem starts, and it would only be able to grab the threaded aluminum of the plate holes?
__________________
Ben
12.26@108.8
7.78@87.7
Stock Turbo Puller
  #14
Old 12-17-2011, 03:36 PM
TheBac's Avatar
Engine: LB7-Z
Default
Quote:
True about the crank. Of course you shouldnt use the trans bosses
I bolted thru the adapter into the block, x.
That pic is getting a lot of mileage.
__________________
Tom
12.14@111.15
-- Retired
  #15
Old 12-17-2011, 03:43 PM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Truck: cc/sb
Engine: lb7
Default
I didnt i just got long bolts and a different length addapters (3/8ths or 1/2 pipe nipples) and took 4 of the 17 mm bolts out of the rear addapter and bolted to the block thru the adapter. WHAT EVER YOU DO DONT USE THE OUTTER 15 MM BOLT HOLES THE EGNIGES WEIGHT WILL SNAP THEM MOST OF THE TIME
__________________
04 LB7 CC/SB EFI live, dsp5 switch, 4 inch Magna flow, Industrial Injection S366,S483 , keystone ram air hood,Big Dipper trans,MBRP hot side IC pipe, rolling on hummer wheels with 315/70/17s wraped in silverbirch.
Carillos, keyed cam, and crank, ported heads,ARP crank and head studs, RDL manifold and uppipes, coated lb7 pistons and some other goodies.
Born again 08/10/2011
11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
