  #1
Old 05-05-2010, 06:39 PM
Rnolan Rnolan is offline
Gearhead
Default Rough idle- injector control circuit
I drove my truck all weekend and parked it Sunday night. On tuesday morning I started it up and the low fuel light came on. I JUST FILLED IT UP SUNDAY. It started to idle really rough, wouldn't rev above about 1800RPMs and has no power. Sometimes it will start and run fine for about a minute, then go back to doing the same thing.
Here are the codes that came up. Anyone know where I can start?
__________________
'02 D/A ECSB, SCV, AirDog 150, TIE ROD SLEEVES, COGNITO BRACES, EFILIVE, AFE STG2, 4'' MBRP
  #2
Old 05-05-2010, 06:42 PM
Gearhead
Default
The codes are:
P0201 INJECTOR 1 CONTROL CIRCUIT
P0204 INJECTOR 4 CONTROL CIRCUIT
P0206 INJECTOR 6 CONTROL CIRCUIT
P0207 INJECTOR 7 CONTROL CIRCUIT
P1261 INJECTOR POSITIVE VOLTAGE CONTROL CIRCUIT GROUP
__________________
  #3
Old 05-29-2010, 06:04 AM
steakman's Avatar
steakman steakman is offline
Diesel Nut...
Default
did you get this figured out..??
Well seeing as I am having similar issues. This is an electrical issue. I know it happens frequently to LLY and LB7 engines. Guys have told me that to check the injector harness where it goes to the FICM. It is apparently tie wrapped at some point to the alternator bracket at a sharp edge. Yolu may have some seriously chafed wires there..??
I'm still trying to figure my issue out but its on an LBZ and supposedly these issues do nto happen to them..yea right.! I threw P2149/P0207 ... Injector # 7 did the Ice pick manouvre..still no joy. I have connectivity but it isnt 100%.
Good luck and I'll watch this thread as well as start a new post on my issues and questions.
cheers,
Theo
__________________
"the ghost"
06 GMC LBZ CCSB
...a bit of stuff...
174,035 miles
  #4
Old 05-29-2010, 06:54 AM
jlawles2 jlawles2 is offline
Default
On the 02, check for harness rub. The wiring harness rubs on the aluminum bracket for the alternator and wears the insulation off the wires, then they go to ground and it causes issues. Common on most of the trucks.
If you do have harness rub, fix the missing insulation, broke wires. Then use a piece of rubber heater hose to protect the wires from rubbing through again.
__________________
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #5
Old 01-04-2014, 07:12 PM
Vernon Stoltzfus Vernon Stoltzfus is offline
FNG
Default
What did you guys find on this issue? have the same thing on a lmm
__________________
05 LLY
s475 over stock
PPE Dual Fuelers
Built transmission by Blackout Performance
Efilive tuned by Blackout Performance
  #6
Old 03-10-2014, 05:44 AM
MaxSmoke's Avatar
MaxSmoke MaxSmoke is offline
FNG for life
Default
Did you figure out what the issue was? Just did injectors on my buddy's 03 sat and having the exact same problem after we fired it up. Thanks!
__________________
04 LB7, PPE standard, Flo-pro d/p, 2" lowering shackles. Fass 150, Wetzel wheel, Air bags
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
